Author Topic: Open source lxi-tools v2.7 released  (Read 21508 times)
Offline bicycleguy
Re: Open source lxi-tools v2.7 released
« Reply #100 on: August 23, 2023, 08:52:48 pm »
FYI  was able to install lxi-tools v2.7 from brew as in last post on a M2 MacBook Air.  It had a few error messages suggesting updating stuff I already had, including Xcode tools and Python2 which I didn't do as I'm Python3.  With that, I was surprised it seems to work.
I use mostly for TestController.
The following users thanked this post: lundmar
Offline dobsonr741
« Reply #101 on: February 03, 2024, 10:43:34 pm »
Can the liblxi be used to develop LXI devices?
I know, that lxi tools was developed as a LXI host, to connect with LXI devices. But I thought, that liblxi contains all the functionality to support both the host side as well as the device side. So, would it be possible to expose ADCs/DACs on a Raspberry Pi (maybe from a HAT) as an LXI instrument, with the liblxi?
That would be very good, to one central LXI host and device code base.
I'm on the same boat, I want to add VXI-11 connectivity to a device that I'm developing. What libraries did you end up using?
Would anyone be able make progress on creating LXI devices?
Offline lundmarTopic starter
« Reply #102 on: March 27, 2024, 07:40:54 pm »
Yes, I am planning to release both VXI11 and HiSlip server implementations in C as open source.
https://lxi-tools.github.io - Open source LXI tools
https://tio.github.io - A simple serial device I/O tool
The following users thanked this post: RoGeorge, MegaVolt
