I had to go back and update the benchmark performance numbers for the Siglent SDS1204X-E because it turns out my network routing tables were messed up so all tests were performed over wifi - arrghhhh! ![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Over cabled network it's not doing ~300 requests/second.... It's doing ~1100 requests/second!!!!
Bam! Thats almost as fast as a Dolorean in overdrive!
With such result there is plenty room to make a poor-mans-datalogger sampling maybe several values at e.g. 100Hz or more.
Oh, and the screenshot live view feature in lxi-gui is now even more smooth hitting about 7 frames/second.
I haven't looked into this software for my oscilloscope (1054z), but I wanted to point out two things I learned when testing various software and hardware configurations in an effort to get the fastest screen capture of the 1054z to make videos/GIFs.
The first thing I learned is that, for the 1054z at least, there is a big difference in screen capture speed over ethernet versus USB; and furthermore this difference changes depending on OS. In my case (Linux) the USB capture was the fastest (maximum capture rate is about 1/3 of a second versus about 2 seconds).
So once I settled on the software and the USB screen capture method, I used the
Rigol Bildschirmkopie software to capture "as fast as possible" (the next fastest option being once per second).
However while this does work, it causes many in-scope computed functions to slow down or cease computing entirely! This includes things like updating the various measurement items at the bottom of the screen; it includes the MATH functionality, and it includes the FFT. In other words, while the oscilloscope trace itself would be correct on every screen capture (every 1/3 of a second), the reported measured values would just freeze and stay the same (on both the oscilloscope and the captured screen). The FFT would freeze. And so on.
I'm aware of the notion that one of the main advantages of these new Siglent oscilloscopes is that they are faster, but I wanted to make sure you keep this in mind when doing tests and make sure to report this kind of behavior if you see it. If you do see it, it may be helpful to report the fastest synthetic test to get screen captures and also report how much slower you have to go, if any, to get all features on the screen to update.
As a corollary to this, since it seems the behavior of the Rigol is to
drop updating certain on-screen functions if screenshot requests are made too fast, perhaps the Siglent behaves differently: it may slow down screenshot capture rates if there is much more computation going on. Perhaps this is worth testing too.
In any case, please capture a bunch of screenshots and use some software to string them together into a GIF so you can post it here and show off how pretty it is.
I use the free software GIMP, and the steps are pretty easy:
1. "Open as Layers" all of the captures.
2. Do Filters -> Animation -> Optimize (for GIF)
3. Export as GIF, and be sure to set: export as animation, set a reasonable delay between frames, use delay for all frames, and select combine.
I look forward to seeing some samples of what that scope can do in this regard!
