Author Topic: Small Bench-Top Temperature Test Chamber  (Read 1093 times)
Offline 741Topic starter
    • Circuit & PCB Design (small PCB quantities OK)
« on: February 13, 2023, 01:51:30 pm »
We are testing electronic assemblies, including (as yet undecided type) batteries.
Specifications/Requirements
   Ability to set a time-temperature profile (PC control ideally)
   -25C to + 40C range (No requirement for external coolant)
   Able to accommodate a 'box' with dimensions 285 x 250 x 140mm = 11.2 x 9.8 x 5.5 inches
   Budget about £4k
I don't know if the above budget is realistic - After lots of searching, I've not found anything that seems to approach the above wish-list.
Most results are over-the-top in terms of specification, size and cost.
Offline mendip_discovery
Re: Small Bench-Top Temperature Test Chamber
« Reply #1 on: February 13, 2023, 06:37:09 pm »
TiN has some instructions over on xdevs for the kind of setup he uses.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
