Yes, I´m Spanish. I am very curious to know how you got the commands to read the flash, theoretically they are recorded in the kernel, right? I have searched a lot on the internet and I have not found anything!
Quote from: harrimansat on November 02, 2020, 12:43:27 pmYes, I´m Spanish. I am very curious to know how you got the commands to read the flash, theoretically they are recorded in the kernel, right? I have searched a lot on the internet and I have not found anything!Hola I did a text search in the code that jellytot posted earlier in this thread. The known commands are there plus a few others that looked interesting. They didn't work in normal mode so I tried them in the kernel and kept trying different things until I worked out what they did, bit of a treasure hunt really.All the commands are at offset 0x6e35 in your 2.BIN file.They must be implemented in the kernel because they work when the flash is erased but they're also in the list in the main code.There's still a couple commands I haven't worked out the use of so far CL and DW
I will make another backup and post it.I would like to flash a 105b eeprom in my 105. I have two fluke 97, one of them is "rare" it has a 5.00 hardware, I would like to try if it accepts the 105 firmware too.Thanks!
yes, that one is version 4.02 so no problem
Quote from: marrob on November 03, 2020, 01:21:17 pmyes, that one is version 4.02 so no problemUsing PF?How?
Big thank you to Marrob for new software to take the sting out of pulling out data from the Flash chip/chips. Will try it tonight since I am struggling with QF. Found something unusual last night in my first attempt. Sent ID to a non working PM95 and it sent back SCOPEMETER 90 FAMILY MSK V2.01 02-15-91. Does this indicate that it is somehow locked within the kernel ?Will post any further results in the next few days.
OK yes, it has been a long time and I am very rusty but got half way there. Can not get any flash dumps from working or non working but got a cal.bin from a working PM97. Will update when I get some more.
I will go back to it tonight with a usb adaptor and try to lift everything from the PM95, 97, 96b II and 99II models (working or not) and get them posted on here for everyone to play with.
Hi,I have made a adaptor to use BNC input with multimeter leads. Is a 10:1 attenunator with HV voltage capacitors to compensate HF. It can measure up to 3kvRegards
Hi, I have a FLUKE97, I can´t locate this board in service manual. There is more services manuals for these scopes?
