Author Topic: Old Fluke Multimeters  (Read 400583 times)
Re: Old Fluke Multimeters
« Reply #675 on: July 05, 2019, 07:45:16 am »
The image I used was of mrmodemhead.  This is the plate of my multimeter.  It is somewhat blurred.  Sorry for my lousy English
Your English is far better than that worthless blurry photo !
Upload a better one please.
The following users thanked this post: Pablitox
Offline Electro Detective
« Reply #676 on: July 05, 2019, 09:41:23 am »
The blurred image when flipped 180, and compared with previous image, sort of tells the story
'Perhaps' that board revision gave that cap a miss for whatever reason,
or the next stage didn't need it,
or... =  :-//
or need Mr. Taylor in on this one again  :clap:
@Pablitox: does the meter work ok as is, and sort of agrees with another meter you have ?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #677 on: July 05, 2019, 03:04:45 pm »
To me the difference between a concave and a convex solder blob may indicate the meter had a component soldered there at a certain point in time.
At any rate, the recommendation from the designer holds more water than any attempt to reconstruct the history of the device and find any potential reasons.  :-+
Offline Pablitox
  • Country: ar
« Reply #678 on: July 05, 2019, 06:24:28 pm »
Offline Pablitox
  • Country: ar
« Reply #679 on: July 05, 2019, 06:26:14 pm »
I do not have another better camera :(
Change the electrolytic and clean with alcohol and air
« Reply #680 on: July 05, 2019, 10:26:14 pm »
So apparently there should be no cap there ? perhaps cap compensation is elsewhere on the PCB as per Revision?
I would leave as is if the meter is working ok, and has been for years and years
I've come across gear before with blank or solder filled holes   (...Dude, where's my cap?!   :-// )
and just assumed they are there to solder in a component if necessary due to circuit/parts tolerances out of wack or ripple etc at assembly time
On the other hand, if it was a slimy penny pinching exercise to save .5 cents at manufacturing  :palm: and THAT circuit may/would benefit with no possible harm or CAL hit,
hey, give it a go  :-+
Offline Pablitox
  • Country: ar
« Reply #681 on: July 06, 2019, 05:56:47 pm »
If something works well, do not touch.
And this Fluke 8060a works excellent. No calibration was necessary. I used it used
Offline rsjsouza
  • Eternally curious
« Reply #682 on: July 07, 2019, 12:47:56 am »
Well, I'll eat my hat. Both my 8060A and 8062A do not have this capacitor fitted.  :-//
8060A S/N: 4245166
8062A S/N: 4210192
The bad flux residue is due to my inexperience in properly cleaning boards at the time I recapped this meter.
The 8062A still has the original capacitors. None leaked, but it will go under surgery soon.
« Last Edit: July 07, 2019, 12:53:09 am by rsjsouza »
The following users thanked this post: Electro Detective
« Reply #683 on: July 07, 2019, 11:06:10 am »
I'll have to crack open mine too asap
and hope I too am not a victim of the Fluke Cap Burglar  :scared:
 :D
Offline Alex P
« Reply #684 on: July 09, 2019, 06:21:43 pm »
Had a look at a few 806x meters:
8060A, s/n 4395401,      pcb rev F: has the capacitor (IC date codes from 1982)
8060A, s/n (none seen), pcb rev H: does not have the capacitor (IC date codes from 1987)
8062A, s/n 5035011,      pcb rev J: does not have the capacitor (IC date code from 1989)
Where the C is absent, the soldering islands look like straight from the factory, no sign of removal or additional soldering.
« Last Edit: July 09, 2019, 06:28:17 pm by Alex P »
The following users thanked this post: rsjsouza, Electro Detective
Offline rsjsouza
  • Eternally curious
« Reply #685 on: July 09, 2019, 07:31:06 pm »
I found in my hard disk some older downloads where I got the schematics and component placements and it seems the capacitor in question is C28: 10µF/16V in parallel with the zener voltage reference VRZ.
Why this was removed is a mystery, but perhaps it was suitable for stability?
Rev 1
Rev 3
Unfortunately the full scans are too large to be attached, so I did a search on the manuals and found that Mr ModemHead was kind enough to scan his copies and make them available at:
https://www.eevblog.com/forum/testgear/fluke-8060a-calibration-service/msg1462267/#msg1462267
(obviously he also mentions the C28 mystery)
« Reply #686 on: July 10, 2019, 12:20:07 am »
...C28 is a 10uF across the 1.2V bandgap reference.  To be honest, I hadn't noticed that it disappeared at some point in the lifespan of the design.  I have hardcopy documentation from 1983 and 1988.
C28 exists in the 1983 rev, but is not mentioned in the 1988 and the much-later PDFs available on-line from the Fluke archives.
If it is not in your meter then there should be no need to include it..
Let sleeping dawgs be for now,
well until more intel flows in..   ;D
Offline IconicPCB
« Reply #687 on: July 10, 2019, 02:58:17 am »
Looking at the schematic the current for the zener is sourced via Z3 a 50K resistor.
It is possible electrolytic's leakage current may have been detrimental to the stability of the reference voltage.
I see no reason why a low leakage film capacitor could not be used there.
Offline rsjsouza
  • Eternally curious
« Reply #688 on: July 10, 2019, 10:39:36 am »
The issue there is space. If you want to keep the same 10uF that will take you to MLCC territory. How is leakage on these types of capacitors?
You could also derate its voltage for even less leakage (use 25V instead of 16V).
Edit: found some info at Murata, which places their MLCCs typically at 500MΩ-μF - this yields 50MΩ for a 10µF capacitor.
« Last Edit: July 10, 2019, 11:52:20 am by rsjsouza »
Offline coromonadalix
« Reply #689 on: July 10, 2019, 10:46:09 am »
 fluke 8060a, the 40 pins main  ic could be an intersil 7106- 7107 series ??
« Reply #690 on: July 10, 2019, 10:52:22 am »
It's a different IC. Similar design, at least from the 8000 flukes. I think the story is that Fluke developed the original IC with Intersil as a foundry and Intersil nicked part of it and sold the ICL7xxx series and Fluke weren't happy.
« Reply #691 on: July 10, 2019, 10:57:21 am »
Yep, info all about this in posts #1 and 17 of this thread.
Offline rsjsouza
  • Eternally curious
« Reply #692 on: July 10, 2019, 11:44:31 am »
Not at all. The 8060A has 20000 counts while the 7106/07 has only 2000 counts.
What tautech and bd139 mentioned is applicable for the 802x series.
Offline IconicPCB
« Reply #693 on: July 10, 2019, 11:58:34 pm »
I think the original cap was an aluminium elctolytic and hence the comment on leakage current.
« Reply #694 on: July 12, 2019, 10:50:47 pm »
I didn't know EEVblog host DJ did a cool test/quickie teardown of an RS badged 8060A during "EEVblog #802 - Mailbag" Youtube, 'published on Sep 28, 2015'
Not sure if that YT link has been posted here already  :-// well, here it is again for those that missed it
youtube.com/watch?v=F_REyGWNAmc
or hit on the Mailbag page here on the forum that has the embedded? video >  www.eevblog.com/forum/blog/eevblog-802-mailbag/?all
The entire Mailbag is a good watch (as they tend to be  :clap:) the 8060A feature kicks off about 3 minutes in, and runs for about 6 mins,
and yes 'That's A Knife' also does a cameo appearance  :scared:
Please note: at about the 6.35 minute mark, clear evidence that pesky Fluke Cap Burglar rolled over that meter whilst in transit to DJ  :D
:palm:
« Last Edit: July 12, 2019, 11:08:51 pm by Electro Detective »
« Reply #695 on: July 21, 2019, 03:55:23 pm »
Recently scored an 8840A for the equivalent of around US$110, with the AC-09 option. Sadly no GPIB option, but meh...
The Micronta you see was my pride and joy, bought it new in '87 or '88, cost £70 which was half a weeks wage at the time, and added the shrouded sockets in '95 or so... safety first! 8-)
The Black Star is a recent add also, and has some issues... if there's anyone out there with good knowledge of the error codes on these, please pm me...
Offline EEVblog
« Reply #696 on: July 29, 2019, 01:29:13 pm »
I lusted after that thing back in the day!
Offline smmi
« Reply #697 on: August 01, 2019, 06:35:05 am »
hey Dave Taylor (if you're reading or see this)... you told me I needed to recap my 8060A, as I do plan to pass it onto my son...  ;)
I must lead a charmed life... 8060A (original owner) purchased new, in 1984 - used exclusively in my studio for cal, db and repairs... god bless audio-head meter engineers like yourself...
Meter specifics:
30-84 date code on the MAC @ U3...
serial number 3890330...
pcb revision H on the silkscreen... H-1 brown-tagged on the board...
also, C28, 10uF - is NOT populated on this board (per the later component list and schematic)...
Knowing that I needed to re-cap it, just because -  I popped open the meter tonight (after ordering the parts) to see how many caps have let loose (assuming time did the inevitable) - and I'll be darned... not a single cap has leaked... still looks like a virgin... how weird...
In 35 years, this meter has never even looked at me funny... impressive... heck of a job...
btw, if you want to measure a set of intact 35 year old caps to see how much they've wandered (as these haven't imploded)... send me a pm and I'll send 'em to you...
you the man, Dave... Thanks...
« Last Edit: August 01, 2019, 06:40:22 am by smmi »
Offline ogdento
« Reply #698 on: August 07, 2019, 09:26:35 pm »
Hey Smmi that is great luck... they're much easier to re-cap when they haven't already made an awful mess!
I just opened up this guy and was excited to find my first ceramic MAC... aaand it's got capacitor puke on a few pins.  I hope I don't wreck it pulling it out.
The following users thanked this post: smmi, Marco1971
Offline smmi
« Reply #699 on: August 11, 2019, 04:47:07 pm »
hey ogdento...  sometimes we get lucky... sometimes we don't...
that's a big cleanup job on that meter... thank goodness for modemhead's blog and dave taylor's comments up here - for me anyway... and geez what happened to the alt-power battery eliminator jack's input cover? - is that from the spewed electrolyte?... that big blob of green on the MAC certainly seemed telltale...
after I recap this 8060A, I'm going to tear into my 87 (a knock-around spare I've had for years) and clean the display's zebra strips so it gets dark-dark again - I hope that's all it is... 99-isopropyl is our friend... good luck...
