Author Topic: hi i need hex file LCR transistor tester by efan & haoqixin v2.68  (Read 6523 times)
Offline mourad3dTopic starter
hi
i need  hex & eeprom files LCR transistor tester by efan & haoqixin v2.68
Re: hi i need hex file LCR transistor tester by efan & haoqixin v2.68
« Reply #1 on: April 21, 2017, 12:10:50 pm »
plz help me
Offline azer
  • Country: va
« Reply #2 on: April 21, 2017, 01:33:05 pm »
The firmware is based on the one talked about in this thread
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
but with some modifications by the chinese for the display type and I think the addition of the graphics and it is usually referred to as the Mtester if you do a serach on the forum.
If you ask in the thread they could help you compiling the firmware suitable for your device.
An older firmware for the Mtester is available here
https://www.eevblog.com/forum/testgear/lcr-t4-mtester-v2-07-lcr-meter-black-block-issue/msg879842/#msg879842
and here
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/msg932736/#msg932736
You can sometimes also ask the seller of the device for new firmwares.
