Author Topic: ODP3032 - Experience?  (Read 11004 times)
Offline con-f-useTopic starter
  • Country: at
« on: September 17, 2013, 02:34:40 pm »
Did anyone here use/open an Owon ODP3032? If so would you recommend it? The stats look perfect for my purposes.
« Last Edit: January 15, 2014, 09:41:24 am by con-f-use »
Offline hankee
Re: ODP3032 - Experience?
« Reply #1 on: January 15, 2014, 09:18:16 am »
Nobody?
I am also interested in this product
Offline aflex
    • PCB Manufacturing & Designing
« Reply #2 on: January 15, 2014, 10:08:20 am »
I suggest you should go for it. The features and specifications are too good to say a NO to this. Also, what is the primarily need for this.
Offline ielektros
    • Notebook Reparatur Deutschland
« Reply #3 on: March 10, 2014, 09:57:02 am »
Here is some photos. https://www.dropbox.com/sh/z2uoovvaysdciyk/cxIdf0YRvK
Some photo from last year and made with phone cam. But today I made some new with a bit better resolution.
The display has horrible viewing angles.... The built in LCD type is ACX503AKP-7 339A41D
I like this PSU but the FAN controlling make me crazy. That have a "noise" in standby if no load on outputs.
On a dropbox link a folder too the name is "fan control". There is some pictures. Looks like without load the FAN get only 2,7V effective. And a crazy controlling signal... That is 1kHz "something". Thats why the fan have this stupid "beep" tone. Sorry because of my english...
The FAN noise problem is solved. Added 330nF between the TIP42C and the other transistor. See on the picture. Now till the output load not over 150mA, the FAN stay stopped. Over 200mA start to work. That is better for the TIP42C too because the transistor was really hot.
Dangerous "bug".   :wtf:
If I turn the PSU to paralell mode (30V 6A), than just I see 14.28VDC on the output  :-// :wtf: Of course the outputs are turned OFF! First I thought that is some "fake" voltage from somewhere but, there I see 10.22mA too. Without stop and every time in paralell mode. This is really a bad joke.
Uploaded some photos to "paralell bug" folder.
« Last Edit: March 10, 2014, 12:23:47 pm by ielektros »
  • Country: at
« Reply #4 on: March 10, 2014, 02:07:14 pm »
Awesome. Thanks for sharing!
Offline hankee
« Reply #5 on: March 10, 2014, 07:38:40 pm »
thank you very much
 330 nF also works ok here
parallel bug gives 4.6 Volt @ 2.1 mA
Offline ielektros
« Reply #6 on: March 10, 2014, 08:31:42 pm »
thank you very much
Looks like I´m not alone  :-/O
That was really a irritating noise for me a whole day. I don´t turn it on and off every half hour. But I really don´t understand the thinking behind, because before the 330nF the FAN does not spinning without load. Only the coils generated noise ;D
What is your opinion about the paralell connected bug? If I have  bit more time I want to check a little bit better. That is really dangerous with sensitive mA range engineering. If I turn OFF the output, that must be really OFF. 4-10mA 4-14V is not acceptable.
Offline mhlvos
« Reply #7 on: July 12, 2014, 04:12:48 pm »
I just got this thing and with sv 1.9 and hv 1.8 I don't have this weird voltage on output while output is switched off issue. Further I did some measurements on the start-up voltage without load and with load. And the start-up behaviour is very nice. No overshoot. But if you put a constant current load on the power supply near its maximum capacity chances are the start-up behaviour is not so pretty. On the other hand a resistive load works fine with max load. The 5 volt is in my case not really 5 volt. Under loads up to say 500 mA it is but above that the voltage raises slowly to a certain maximum ???. Mmmmm. The normal outputs don't suffer from this 'feature' let's call it power line voltage drop compensation :-). So other then some weird behaviour of the 5 Volt and start-up behaviour with max constant current load it works perfectly. I am not sure how other PSU behave with a max constant current load during start-up. They might show the same behaviour. Does anyone have information about this PSU like a maintenance manual or a schematic?
Update: I contacted Owon about the 5 Volt problem and they where very helpful. 2nd of October they sent me a replacement PCB with the problem solved.  :-+ :-+ :-+
« Last Edit: October 02, 2014, 11:54:07 am by mhlvos »
Offline nakunda
« Reply #8 on: January 06, 2015, 03:04:51 am »
hi,
are you able to provide the sv and hv of the new pcb you received?
thanks
Offline mhlvos
« Reply #9 on: March 02, 2015, 10:39:49 pm »
hi,
thanks
The only change made to one pcb was a different potentiometer as far as I could see. No sw changes. It seemed a bit overkill for me to send a complete pcb when I could have replaced the pot.
Offline ErikTheNorwegian
  • Country: no
  • Asberger, aspi, HIGH function, nerd...
« Reply #10 on: October 19, 2015, 06:51:18 pm »
How is the experience with the powersupplay so far?  ::)
/Erik
Goooood karma is flowing..
Offline Arielo
  • Country: ar
« Reply #11 on: February 03, 2017, 03:35:35 pm »
Hello, I'm sorry to bother you, but I'm interested in buying this PSU, and it would be nice to see some photos of the teardown, but your link doesn't seem to exist anymore. Could you please update it?
Thanks.
Offline garboui
« Reply #12 on: February 09, 2017, 12:59:55 pm »
I bought this same supply about 2 years ago. It did the job and with reasonably clean power and load stability. However I did experience the cheap supply turn on spike. The solution to this was to turn on the PSU, use the soft buttons to disable the channel, connect DUT then enable channel. The current readings on the display were only reasonable accurate for currents >150mA. The transformer had a hum that varied at random (with or without a load) which was mildly annoying.
Offline AlphaRomeo
  • Country: ph
« Reply #13 on: April 24, 2017, 09:41:42 pm »
I've used a little more the power supply,  so here is my experience.  I have done the “brutal test” (per the manual) by shorting with a wire the outputs, the power supply recovers very quick. I have done this at a different voltage and current levels. No issues here.
PROS:
1-Very clean power outputs, my DMM does not indicate any AC noise. The scope indicates some noise at a very low level.
2-All three power outputs do not share grounds, they are floating grounds.
3-There are 4 modes of operation: series, parallel, independent, and plus-minus. In the “plus-minus” mode you set it up let’s say -3V and +3V, the output will swing between -3V and +3V volts. In this case, it  can be wired as a bipolar source to test a system in which independent positive and negative supplies are needed, or some other investigative projects. I really like this.
4-It remembers the power level you set it up after is power off and on again.
5-Nice color LCD display, not the best but way much better that an old-fashioned LED type.
6-It does not use a toroidal(donut type) transformer that we see on most power supply, this one uses the EI type. There are pros and cons about them, but I think the EI type is much better.
CONS:
1- The fan is very noise, with not load is kind of quiet, but as soon as a load is applied, it becomes very loud.
2- The modes listed above the way they are indicated on the display is confusing. They are shown by some tiny icons on top of the display that you need to either memorize them or keep the manual next to you. They better do some work here.
3- The sound produced by the buzzer is very annoying. It sounds like a cheap toy. I turned it off right away, still makes the beep when is power up.
4- The buttons do not work the way you may expect, sometimes you need to press them more   than once, that kind of details. Not really the best keypad.
5- The two variable outputs are not dual-banana compatible. The green jack which is the AC ground is in between the – and +, so is the fixed 5 volts output, it is not dual-banana compatible. These guys were smoking weed when they designed this thing. This sucks!
 6- The Amp meter minimum current indicator is somewhere 150mA, less than this you  see nothing, a blank display. The same is for voltage. The minimum voltage indicated is about 4mV. My DMM sees 1 mV output, but the display will not show that until the voltage is set to somewhere 4 mV.
7-The front and back covers are plastic, but the sides are metal.
Over all is a good power supply, so far so good, and the price is right.
« Last Edit: April 30, 2017, 01:25:32 pm by AlphaRomeo »
The following users thanked this post: kado, Arielo
Offline ramin110
  • Country: ir
