This Thread is about the New Digilent Digital Discovery Logic analyzer. The product announcement was on March 17th. I have one on order and it will be in on Thursday, so I'm jumping the gun by a few days. Hopefully we can set up what to do to review it in that time. Since this is one of the first 100 purchases, they are including the High speed adapter and wires, so it will be complete with all options.
I figure this can be a review/learning experience. I have limited knowledge in modern electronics and zero experience with a logic analyzer, and will be seeking input from the group about finding out what this thing can and cannot do. So, if anyone is interested, I can make some simple circuits and put it to the test. i have just put my electronics bench together, so there is some, but not a lot to work with. i don't mind buying parts to make test circuits.
![](http://cdn6.bigcommerce.com/s-7gavg/products/544/images/4431/Digital_Discovery_-_Oblique_-_600__69794.1489168972.1280.1280.png?c=2)
With all that in mind, here is the webpage at Digilent.:
http://store.digilentinc.com/digital-discovery-portable-logic-analyzer-and-digital-pattern-generator/As far as what is available that I can find on their site, the doc look pretty slim. It initially seems to be marketed not to the beginner, like the Analog discovery, but to those with working knowledge of using a analyzer. Even with what they have, I am already lost on part of it. Maybe we can find a procedure to follow to test it all out.
Features:9.1. Logic Analyzer
24 high-speed input channels (DIN0…23), accessible through one 2×16 connector, used with the Logic Analyzer in Waveforms (560k?||10pF)
16 digital I/Os (DIO24…39) arranged in two Pmod-style (2×6) connectors, used with the Logic Analyzer in Waveforms 1)
800MSps input sample rate when using maximum 8 inputs (and the High Speed Adapter), 400 MSps with maximum 16 inputs (with the High Speed Adapter), 200MSps and lower with maximum 32 inputs 2)
User programmable input and output LVCMOS voltage levels from 1.2V to 3.3V 3) (5V compatible 4) )
100MHz signal input bandwidth
2Gbit DDR3 acquisition buffer for Logic Analyzer
Multiple trigger options including pin change, bus pattern, etc 5)
Digital Bus Analyzers (SPI, I²C, UART, Parallel)
9.2. Multi-purpose Digital I/O
16 digital I/Os arranged in two Pmod-style (2×6) connectors.
Each of the 16 pins can be configured for input (Logic analyzer) or set as output 6).
Algorithmic pattern generator (no buffers used) 7)
Custom pattern buffer/ch.: 32Ksamples
ROM Logic for implementing user defined Boolean functions and State Machines
Bus Protocol Controllers (SPI, UART, I²C)
100MSps max. output sample rate (50MHz maximum output frequency).
Automatic or manual strength and slew settings for outputs.
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
User programmable logic I/O levels from 1.2V to 3.3V (5V compatible) 9),10).
9.3. Other features
USB bus powered
User power supplies, 1.2V to 3.3V, available in the two Pmod-style connectors (100mA max)
Twisted wire high-speed cable option for input channels to insure signal integrity
Free Waveforms 2015 software runs on Windows, MacOS, and Linux
Cross-triggering between Logic Analyzer, Pattern Generator or external trigger
Data file import/export using standard formats
80X80X25mm, 80g (without accessories)
includes: USB cable, fly-wire accessory
