Hello everyone,
The TDS 3014 series are great oscilloscopes. However when the batterie of the DALLAS DS1745-150 starts to fail its frustrating to find a replacement that works.
First things first, desolder the Dallas chip was painful since I do not have a Desoldering Tool. So, if you find yourself in the same situation I will recommend to use solder wick. Using a desoldering pump may cause damage to the board (lift traces or pads). Make sure you cut off the part of the solder wick that you already used to avoid loss in the heat transfer.
I'll recommend to use a 24 pins socket, to make it easy in the future to replace the NVRAM. If you are having a hard time getting the DALLAS chip you can use the M48T02-150PC1 it works fine, the only thing is that the DALLAS chip has a supply voltage 3.3V while the M48T02-150PC1 needs from 4.7 V - 5.5 V.
Voltage supply is on pin 24, so, if you used a socket you could cover the hole on pin 24, bend the leg of the chip and solder a cable you can connect to pin 2, 3 or 4 of J900. Once you turn ON your oscilloscope you will see the screen turns pink
really frustrating after all that effort... But it has an easy solution, just press SAVE/RECALL → FACTORY RECALL SETUP → OK CONFIRM FACTORY INIT.
Don't forget to configure the right date and time.
I hope this was helpful
