Author Topic: Re: ANENG 8008 mod for faster more accurate readings.  (Read 3023 times)
Offline wilfredTopic starter
« on: June 05, 2019, 05:47:56 am »
 #ANENGMOD
I found this blog post whilst searching for failed backlights on this meter. It tackles noise spikes on the supply with more and better (lower ESR) capacitor.
https://www.jackenhack.com/aneng-an8008-modify-for-better-accuracy-faster-readings/
Has anyone here tried it or got some thoughts about how effective it might be?
Known backlight issues would help too.
« Last Edit: June 05, 2019, 06:40:15 am by wilfred »
Offline floobydust
Re: ANENG 8008 mod for faster more accutate readings.
« Reply #1 on: June 05, 2019, 06:09:31 am »
I figured out the AN8008 cap mod in July 2017, so a few people later posted it in their blogs.
Adding 3VDC rail ceramic capacitors is a huge improvement in settling time and stability for readings.
Without them, the noisy 3V rail causes the averaging algorithm to take longer or simply never settle down so the last digit is always moving around.
I've had no hassles with the LED backlight.
The following users thanked this post: Kean
« Reply #2 on: June 05, 2019, 06:26:55 am »
Sorry @Floobydust I did do a search for prior threads but obviously I missed your post. The title wasn't any indication of modding the thing.
Here's another link to it for future seekers.
https://www.eevblog.com/forum/testgear/an8008-us-$19-10000count-1uv-0-01ua-0-01ohm-resolution-meter/msg1261300/#msg1261300
Thanks.
#ANENGMOD
« Last Edit: June 05, 2019, 06:44:35 am by wilfred »
The following users thanked this post: Marco1971
