Author Topic: Rigol DM3068 Calibration  (Read 18221 times)
Offline bdunham7
Re: Rigol DM3068 Calibration
« Reply #25 on: February 21, 2024, 06:24:13 pm »
You can't make this stuff up (the story, I mean, not the certificate).  I'm honestly too amused at this point to be mad.
Shocking...but not surprising.   :-[
After all, the meter is (probably) accurate within spec and you have your certificate in hand.  They're probably genuinely perplexed as to what the problem might be.
Is the serial number physically on the back of the case as well as shown on the display?  And now they don't match?   :palm:
Offline slugrustleTopic starter
« Reply #26 on: February 21, 2024, 07:39:15 pm »
I think I need a better dictionary ;)
This attitude would be more understandable if it wasn't coming from a company that makes a 6.5 digit bench DMM.
Correct, but it's a sticker on the back of the case, and I have a label maker...
