As in the topic, the problem of a large number of adapters : NI GPIB-USB-HS
From software version 17.6 (NI 488.2) all Chinese adapters (mainly bought on ebay) are detected as not genuine.
So far the solution is to use software version 17.0 (which is also not available on the NI website).
But is this the only solution?
According to me, there should be at least 2 more:
1 - finding a module (entry) in the software which, after detecting an incorrect number, throws this error.
2 - (or even better) find the entry in the adapter's flash memory where the serial number is and change it
Has anyone tried to deal with the topic?
So far, I have not been able to find such an entry neither in the software nor in the memory of the adapter, most likely this value is encrypted in some way.
Although we may be able to achieve something together.
