Hi there,
as you can see from the subject, I'm struggling with this interface. On May 2020, as I was studying Labview, I managed to use the interface with an Agilent multimeter to perform some easy monitoring tasks. After one year, I connected the interface to the instrument but was unable to access it.
NI MAX shows the interface correctly and self test is performed without any issue. As I "scan for instruments" I get a "No instruments were found during the instrument scan". Same problems I have if I connect the interface to an Agilent counter.
May be the interface that "has died" on the GPIB side?
NI I/O trace screenshot is attached.
Thank you in advance for your help.
Best regards.
