I am looking for a voltage output module with which I can stream (close to realtime) a voltage signal from e.g. Matlab or similar.
The output requirements are as follows:
- Frequency range: DC up to min. 50 kHz (preferably 100 - 200 kHz)
- Output voltage: anything between +/- 3 V and +/- 10 V
- DAC resolution: 24 bits
1. for frequencies above 10 Hz I currently use RME sound cards. This is relatively inexpensive but unfortunately DC is not possible with them!
2. for DC I am currently dependent on NI, specifically the Ni-9260 module, but unfortunately the card only manages 51.2 kS/s.
Does anyone know an output module that combines "both worlds" and is open for different operating systems (Windows, Linux, macOS)? I would like to get away from NI hardware for various reasons (which should not be a topic here!). For suggestions and ideas I would be super grateful!
