Try
cd build
cmake --build . -j4
Hello,
Thanks it compiles now, but it's taking quite a while.
The "-j4" tells the compiler (ninja) to use 4 cores on your PC.
It is more than probable that your PC has more than 4 cores.
ninja by default uses all your available cores.
In short run "cmake --build ." without the "j" switch.
Please note that cmake in turn runs ninja => just run "ninja" as fredo_ suggested and advised in the yet unpublished doc mentioned by azonenberg
Best regards
egonotto
PS: Now it's ready. But my SDS3000X HD is not recognized correctly via LAN.
ERROR: Unknown scope type
Then the terminal just returns "ERROR: Unknown scope type"
Try again with the latest version on git, should have the 800 series support merged?
Yup it is merged and seems to work.
I just cloned and compiled from scratch and Siglent SDS824X HD is recognized ... I didn't try yet to really take a capture.
Wil let you know when I had it tested better.
