Author Topic: VESA Mount for the Rigol MSO5000 series Oscilloscope (Sharing my design)  (Read 880 times)
jerryk and 1 Guest are viewing this topic.
Offline ken830Topic starter
I'm not 100% sure this is the right forum section to share this in, so forgive me if I got it wrong and let me know where to post this.
I want to share my design of a VESA mount for the Rigol MSO5000.
https://makerworld.com/en/models/59238#profileId-61286
https://www.thingiverse.com/thing:6301948
https://www.printables.com/model/650617-rigol-mso5000-series-oscilloscope-vesa-mount
I worked really hard on this and after countless prototypes, I'm very happy with the end-result. The mount is low-profile, tool-less, and very sturdy. Should be easy to print with no supports required (only 45-degree overhangs). I've had no problems with it at all in the 2 months I've had it set-up. I hope some of you find it useful.
« Last Edit: July 25, 2024, 02:55:56 am by ken830 »
The following users thanked this post: thm_w, kerni, ilyxa
Re: VESA Mount for the Rigol MSO5000 series Oscilloscope (Sharing my design)
« Reply #1 on: November 07, 2023, 11:36:25 am »
Seem to be having some trouble with attachments. Let me try in this post.
Offline beatman
  • Country: gr
« Reply #2 on: November 07, 2023, 01:21:37 pm »
what about cooling?
« Reply #3 on: November 07, 2023, 01:35:17 pm »
There is about a 7mm (1/4 inch) gap between the mount and the back of the case and open on the sides and top. The right-side (left-side if viewing from the rear) is where the fan is, and that side has more of the vents completely un-obstructed. I haven't noticed the scope getting any warmer than when it was sitting on my desk. I was planning on iteratively cutting out holes/shapes in the design for ventilation while testing for strength, but this seems to work fine so I didn't feel like making more iterations and creating more filament waste.
Just wanted to update this. The scope has been sitting on this mount for just over a year now and still holding up fine. PETG hasn't shown any signs of creeping.
