Where did you get this from? Is there a change log?
Katie/kwass et al., I started a nice post explaining on how to get the updated ZT-703S firmware upgrade, but thought better to install on mine first, but when I did I got the following error message.
![New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)](https://www.eevblog.com/forum/index.php?action=dlattach;topic=353867.0;attach=1984099;image)
I'm trying to contact Zotek (maybe a few hours they will start work) to try and let them know there is an issue, figure out what this exactly mean, and if they can solve it...
In the meanwhile, here is what I was going to originally post... Maybe you have better luck than me...?
@ Katie et al.,
If you go to Zoyi's website here:
https://zotektools.com/products/zoyi-zt-703s/Click "Up Date the File" button/link
Then click "Update the file" button/link
It will take you to a Google Drive and if you click Download it will give you a file called something like:
ZOYI-703S-FW-V127(1).ZTK
I assume the *.ZTK extension is Zoyi's DMM firmware update extension.
To see how to update the firmware there is a YouTube video on how here (with older sister DMM 702S, assume same way to do firmware update)
Nutshell steps (at least for Windows, correct me if I'm wrong)
Turn off ZT-703S
Plug in USB-C cable from PC to ZT-703S
Press F1 and then Power (might have to hold)
On Windows computer should create a new Drive something like RAM E: (note drive letter might be different on your particular computer)
If you go to this new RAM Drive letter it should show a folder called "firmware"
Place the above file *.ZTK inside the "firmware" folder
On the ZT-703S it should show progression bar and "upgrading, do not power off"
