I also just noticed that the new MDP series output signal is 1/2 of the prior DP series (7V -> 3V), which equates to the DP10007 10X/100X probe now equivalent to the MDP701 20X/200X probe - both have 70V / 700V ranges. The change in attenuation from 100X to 200X for the same voltage rating is a bit confusing to me. I would have originally guessed that a larger output signal would provide better S/N measurements - ie 0-3V (seems like it should be 3.5V ?) now represents 0-700V at the 200X setting. That means that every 1V at the scope equates to 200V measured...
I'd really be interested in a review video on these new models - especially how they compare to the old models and also how they compare to the Sapphire probe.
