Author Topic: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)  (Read 262999 times)
Skashkash, Atlan, guyincog and 7 Guests are viewing this topic.
Offline naiclub
  • Country: th
Re: New Zoyi multimeter+oscilloscopes - ZT-70xS, up to 50MHz/250MSps (nov 2022)
« Reply #275 on: February 10, 2024, 07:40:00 am »
(I still can't sell zoyi702, no one is interested)
Offline wedgehog
« Reply #276 on: February 10, 2024, 02:18:24 pm »
Why would anyone want it when 703S is available?
Online Aldo22
« Reply #277 on: February 10, 2024, 04:01:30 pm »
Why would anyone want a 703S?  :-DD
It's all a question of price.
Online RAPo
« Reply #278 on: February 10, 2024, 04:22:24 pm »
... or a scope in the form of a multimeter with a rudimentary x-y functionality.
Offline oliv3r
    • Rigol related stuff!
« Reply #279 on: February 14, 2024, 10:12:24 pm »
Just ordered one after watching the view. While not a super scope; it's imo great to have a portable isolated (cause battery operated) one for on the side. It's like those €5,- multi-meters. Always nice to have 1 or 2 to just have.
I got a MSO5k for my other hobby stuff, that I turn on at least 4 times a year :p
But again, being able to measure without having to worry about shortening anything to ground is still pretty cool. And the portable aspect! For those needs, it's great. I must admit though, I am disappointment they only supplied a single probe :( Even for that price, they could have put in two in the box. Found out they have 'options' when ordering to get a two probe one, so canceled and reordered. Lets see. Still for €90,- it's a nice toy to have in the box.
« Last Edit: February 14, 2024, 10:19:20 pm by oliv3r »
Offline wedgehog
« Reply #280 on: February 15, 2024, 10:44:59 am »
Hi Olly, Exactly, I have a 500mhz 4 input Rigol on the bench, but for a quick look at something away from the bench it's ideal. I find some of the comments I have seen quite incredible, people expect the Earth for £75 or whatever, it's like when you sell a second-hand car fairly cheap and the buyer goes over every inch complaining about a little scratch here and a little dent there. I always say, Oh! you expected a brand new top of the range car for £800! You get what you pay for, especially in electronics, and I think for the price it's wonderful. Yes you will get the second probe thrown in the box beside the little box the scope/meter comes in so be careful when you open it.
The following users thanked this post: BillyD, oliv3r, Randy222
Offline Randy222
« Reply #281 on: February 15, 2024, 04:48:09 pm »
Any word when v1.2.8 will be available from Zoyi site?
Offline Greg J
  • Hi there
« Reply #282 on: February 16, 2024, 01:02:02 pm »
anyone was able to figure out how to turn off sounds yet? When changing mode, it beeps like hell - I hate that stuff.
Take It EV
The following users thanked this post: ddrl46, Razvan_N
Offline Razvan_N
« Reply #283 on: February 21, 2024, 10:00:56 pm »
I have updated the firmware using v1.2.8 from the szzotek.com website and it works well on my unit (boot v1.0.15) although I still cannot tell what is changed in this version :)
If someone from Zotek is reading this: PLEASE put in an option to mute the beeps and bring back the temperature reading!!! We will supply our own thermocouples!
The following users thanked this post: wedgehog
Offline naiclub
  • Country: th
« Reply #284 on: February 22, 2024, 10:44:11 am »
Now is there a solution to the issue of measuring pairs of scopes? Has anyone tried it yet?
Offline Edmiri
  • Country: al
« Reply #285 on: February 23, 2024, 10:12:03 am »
Im having the same issue with calibration, Check Failure.  Did you fpund any solution?
Online RAPo
« Reply #286 on: February 23, 2024, 10:20:45 am »
turn both channels on and do the calibration.
« Last Edit: February 23, 2024, 10:43:08 am by RAPo »
Offline naiclub
  • Country: th
« Reply #287 on: February 23, 2024, 10:39:07 am »
Make a scope that can measure pairs. But why can only measure 1 channel? You are definitely deceiving consumers.
The following users thanked this post: Edmiri
Offline Edmiri
  • Country: al
« Reply #288 on: February 23, 2024, 11:09:41 am »
Well people forget that one channel is off. Plus this is my first scope so im not a pro.
Offline Randy222
« Reply #289 on: February 23, 2024, 03:42:56 pm »
The firmware is bizarre in that regard.
If I hit "cal" then the code "should" prompt you with something like "disconnect all channels, then press MENU to continue", and then from there the cal code does it's thing, and it should turn on both channels at the start of it's routine.
That's what the code "should" do, but it's not coded that way.
Did Zoyi post up v1.2.8 code yet?
Offline Edmiri
  • Country: al
« Reply #290 on: February 23, 2024, 05:09:17 pm »
No. Latest version i could download from zotektools.com is ZOYI-703S-FW-V127(1).ZTK
Offline ha_embedded
« Reply #291 on: February 24, 2024, 05:16:52 pm »
The laser-wiped multimeter chipset in the ZT-703S could be a DTM0660L - at least it seems to have an identical pinout (see below). But there is no indication in the datasheet about 25000 counts capability. The SZ20 from Aneng also uses the DTM0660 and also claims 25000 counts:
https://www.eevblog.com/forum/testgear/aneng-goes-crazy-with-new-meters/msg4773944/#msg4773944
(Aneng SZ20 probably aka Zoyi ZT-225, also 25000 counts)
Anyone familiar with this? Is there a special version of the DTM0660 with higher resolution or is it done with interpolation?
Datasheet DTM0660: https://drive.google.com/file/d/0B6fbSrbAyU1lUlhBQXY3bS1RLU0/view?resourcekey=0-j-BXh9QdU7HVI-Wgu3Gpew
English translation: http://www.kerrywong.com/blog/wp-content/uploads/2016/04/DTM0660DataSheet.pdf
Not important, I am just curious.
« Last Edit: February 25, 2024, 10:08:42 pm by ha_embedded »
Offline Veteran68
« Reply #292 on: February 24, 2024, 06:32:40 pm »
As was posted previously, 1.2.8 is available from the szzotek.com site, which is the Chinese language site for Zotek.
http://www.szzotek.com/h-col-159.html
Offline lchao
  • Country: at
« Reply #293 on: February 26, 2024, 08:45:07 pm »
V1.2.9 update content
1. Fixed the problem that when switching to multimeter mode, pressing F1 to F4 will cause the measurement items and the interface UI to be out of sync.
2. Optimize frequency measurement. When the frequency cannot be measured, the frequency value will become "--.--".
3. Optimize the AUTO strategy, which is faster and more accurate in identification.
4. Fix the problem that the frequency and time base are sometimes inaccurate in high-speed mode.
5. Fix the problem that the signal generator outputs an incorrect frequency in high-speed mode.
6. Fix the possibility that the U disk cannot be opened when FLASH prompts that there is insufficient memory.
Offline Randy222
« Reply #294 on: February 26, 2024, 08:45:48 pm »
But why is it not on the regualt Zoyi site?
Even the domain registration info for szzotek is odd.
Offline Veteran68
« Reply #295 on: February 26, 2024, 11:08:58 pm »
It's behind a private registry service, just like the western zotektools.com site, just a different one. That by itself isn't that uncommon (most of my domains are behind private registrars), although I would expect most legitimate businesses to expose their domain contacts. I was skeptical of szzotek too when it was first mentioned (pretty sure in this thread) and suggested caution, but did some digging and came to conclusion it was legitimately their China-facing site. If you answer the prompt about English, it actually redirects you to the zotektools site.
Many Chinese equipment manufacturers have different internally-facing sites. Also some of them (e.g. Rigol) will post firmware updates to some sites and not others. So this really isn't that unusual.
On a loosely related note, Darren Walker had a Zotek rep on his YT channel a week or so ago when he was unboxing the 703S and asked her about the Zoyi vs Zotek distinction. We all knew they were the same company, but she clarified that Zotek is the western facing brand while Zoyi is the internal to China/Asia brand. She said they weren't allowed to market as Zoyi outside of China, so adopted the name Zotek. She didn't explain why, I assume for trademark or other reasons.
The following users thanked this post: mwb1100
Offline Edmiri
  • Country: al
« Reply #296 on: February 27, 2024, 12:00:43 am »
I know its to much to ask for this but can this scope measure signal noise and ripple to some degree? For example on a atx power supply. If yes whats the best configuration in settings for this purpose?
Offline naiclub
  • Country: th
« Reply #297 on: February 27, 2024, 07:23:55 am »
Where did you get it from?
Offline kloetpatra
« Reply #298 on: February 27, 2024, 10:35:00 am »
What annoys me most is that beeing not in use, negative values causes the digits jumping around, because the string is centered together with the minus sign.
1.2.9 firmware direct link: http://www.dt830.com/forum.php?mod=attachment&aid=NDU1MDl8NjVhZGVjYzJ8MTcwOTAzMDM2M3wwfDgzMzE%3D
The changelog thread and download links: http://www.dt830.com/thread-8331-1-1.html
« Last Edit: February 27, 2024, 10:42:36 am by kloetpatra »
The following users thanked this post: kwass, tonyalbus, Razvan_N
Offline Randy222
« Reply #299 on: February 27, 2024, 03:04:31 pm »
I covered all this a few pages back. Registration of the name is kinda useless. Follow the DNS and stuff. No 'A' record, the name is just a CNAME to some other site.
https://www.eevblog.com/forum/testgear/new-zoyi-multimeteroscilloscopes-zt-70xs-up-to-50mhz250msps-(nov-2022)/msg5316196/#msg5316196
