Official release is today, OP updated with English datasheet and links to western websites.
It looks very good! I wish the pricing was a bit more aggressive, but if they perform as advertised they have nothing to apologize for at $1899 for the SHS1102X.
A couple of questions:
They list the logging as 'sample logging'. I presume that this means that you can only log measurements (like RMS voltage) from the DMM function? Or can you log calculated measurements from the scope like you can with the SDS1x04X-E?
Are the external current shunts included?
The SHS800X models are listed as having an "isolated chassis" as opposed to the "isolated channels" of the SHS1000X. Does this mean it is designed to be safely used for measurements where the ground lead would be floating and the only limitation is that the two channels can't be floating independently? Like an old 90-series ScopeMeter?
SHS1000X have full isolation between two oscilloscope channels and multimeter channel power adapter and USB host/device ports.
Each channel on SHS1000X is isolated from from chassisground and from each others. Just this make SHS1000X very different compared to SHS800X. It can see also in price 689 euro vs 1399 euro. All other features same except isolation (also 1000X have most sensitive range 5mV/div when 800X have 2mV/div. )
And as can easy read from Siglent web side standard accessories include SCD600MA 600mA current measurement adapter and SCD10A, 10A adapter.
SHS1000X models include also PB925 250 MHz 10X passive probes (Safe voltage levels: CAT II 1000 V, CAT III 600 V).
From User Manual can read more:
https://www.siglenteu.com/download/12433/Sample logger and Measure logger starting from page 194.
Isolation: Very big difference between SHS800X and SHS1000X
Look carefully oscilloscope inputs!.
SHS1000X have isolation between channels including also channels GND's. SHS800X do not have isolation between cannels, they have same both same GND.
![](https://www.eevblog.com/forum/testgear/new-x-model-siglent-handhelds-coming/?action=dlattach;attach=1472086;image)
