Author Topic: New Uni-T UPO3254E Oscilloscope  (Read 8837 times)
Offline EEVblogTopic starter
« on: July 22, 2019, 01:43:21 am »
One of these just turned up on my doorstep without notice.
Don't know anything about it, presumably hot off the press.
Quite "busy" looking front panel.
€990 for the 250MHz job
https://eleshop.fr/uni-t-upo3254e-oscilloscope.html
$1000 for the 150MHz UPO3154E
Interesting that the base model is 150MHz instead of the usual 100MHz.
https://www.aliexpress.com/item/32994757798.html?storeId=1110358
« Last Edit: July 22, 2019, 01:47:46 am by EEVblog »
The following users thanked this post: egonotto, thm_w, Marco1971
Offline das_strobel
Re: New Uni-T UPO3254E Oscilloscope
« Reply #1 on: July 22, 2019, 09:49:23 am »
I like the number pad. I guess that's why it is looking busy.
Offline Electro Detective
« Reply #2 on: July 22, 2019, 10:27:31 am »
I don't mind the busy vibe and numbered pad  :-+ but 4 ch and external trigger 'shared controls' is always a deal breaker for me  ::)
I don't want to 'get used to it' or care about 'limitations because of price' etc I'd rather live without it
as it's enough to be thinking about the task at hand, without 'shared controls' mistakes and  :wtf: and |O that goes with it
i.e. each channel should have it's own basic controls right above it = KISS   :-*
Offline edigi
  • Country: hu
« Reply #3 on: July 22, 2019, 11:18:44 am »
I'm always surprised how such basic information like the number of FFT points is omitted from the spec. (or well hidden, I guess not without reason).
Like mentioned above: The rather pointless numerical keys (USB keyboard support could be much superior to it with minimal SW and some optional desk space cost only) and other fancy but equally pointless keys/knobs take space from the much more important per channel controls.
SPI decoding not being part of the base package (optional) is also deal breaker for many.
Entry level scope business is getting pretty crowded nowadays so vendors should pay attention to such (and many more) details...
Note: I don't necessarily mean a complete keyboard with all keys (that can be also beneficial e.g. when giving file names) but num. key only keypads like https://www.ebay.com/sch/i.html?_nkw=usb+numeric+keypad.
« Last Edit: July 22, 2019, 11:46:50 am by edigi »
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #4 on: July 22, 2019, 11:37:14 am »
Almost time to build a head to head comparison spreadsheet to compare all the scopes entering this sub $1k price bracket.
Does something like that exist?
Offline edigi
  • Country: hu
« Reply #5 on: July 22, 2019, 11:43:50 am »
It's part of the sticky "Digital Oscilloscope Chart" but it's probably hard to keep up with the announcements and also the hacking options.
Offline Grandchuck
« Reply #6 on: July 22, 2019, 04:03:27 pm »
I never used a scope with shared controls and have noticed lots of negative comments about that type of user interface.  Is that due to operator confusion and thus increased usage error?
Online Fungus
« Reply #7 on: July 22, 2019, 04:15:27 pm »
The 'shared controls' goes much deeper than just having a vertical position knob above each input.
When you press a channel button on one of these the whole user interface changes to be centered around that channel (on-screen measurements, etc.) The four buttons are needed even if you have the extra knobs (either that or you have to add a whole extra layer of complexity to the menu structure).
Online Fungus
« Reply #8 on: July 22, 2019, 04:16:26 pm »
If a channel is already selected and you press the button again it turns off the channel. I guess that could be annoying.
Offline maginnovision
« Reply #9 on: July 22, 2019, 05:19:15 pm »
On the R&S you actually have to press it twice. First will bring up channel menu, second would turn it off. And yes, it's operator confusion, lasts about a day.
Online Fungus
« Reply #10 on: July 22, 2019, 06:11:51 pm »
It's easy to turn a channel back on if you accidentally turn it off. Just press the button again.
My guess is that most people learn not to do it after a couple of days of use.
« Last Edit: July 22, 2019, 06:14:30 pm by Fungus »
« Reply #11 on: July 22, 2019, 06:37:56 pm »
Yes, it's very easy, and none of the settings change so I'd call it a non issue. Not to mention there are PLENTY of indicators(in the combined control scopes I have) that it's not easy to make a mistake. Some people just can't cope though.
Offline Old Printer
« Reply #12 on: July 22, 2019, 10:07:41 pm »
Looking at the back, it has video out, but it is a VGA connector not HDMI ??? and the USB connector on the back is a B style connector, don't see many of those anymore either.
Online nctnico
« Reply #13 on: July 22, 2019, 10:42:27 pm »
Not really but it does take an extra button push before you can change a channel setting. Then again it is not so much of an issue with a good touch screen interface.
Offline thm_w
  • Non-expert
« Reply #14 on: July 22, 2019, 10:58:39 pm »
USB type B is still standard on all Rigol gear, a lot of scopes, and a lot of printers. It is the most robust USB connector available. No reason to use something else.
VGA is basically obsolete, although Siglent is using it as well, so there must be some demand behind it. Maybe for classrooms.
« Reply #15 on: July 23, 2019, 01:33:23 am »
It's hard to make a compact 4 CH scope with individual controls.
« Reply #16 on: July 23, 2019, 01:34:59 am »
Yes, changing the wrong channel vertical is inevitable with shared controls.
But worth it for a compact scope format.
« Reply #17 on: July 23, 2019, 01:36:12 am »
I think VGA is there because the processor chipset often includes it for free, so no major BOM price increase.
Offline bitseeker
« Reply #18 on: July 23, 2019, 01:40:51 am »
Interesting. Looks rather Rigol-like, but with more sensible labeling and fonts. ^-^
Offline bitseeker
« Reply #19 on: July 23, 2019, 01:41:53 am »
I concur. Inexpensive addition to the feature list.
Offline cv007
« Reply #20 on: July 23, 2019, 02:19:48 am »
They have room above/below the display. I'll take keyboard keys labeled large enough to read and will take the key press feedback that comes along with it, and throw in a backlight, too. Now you have freed up 24 buttons, and can now throw some real knobs in the main area. While they are at it, they can make the knobs large enough for an adult to use and label them in font size > 6, and in some contrasting colors.
There.
(I can't run a photo editor well enough to add the knobs- just imagine the knobs are from an old tek scope or from an airliner cockpit)
« Last Edit: July 23, 2019, 02:21:58 am by cv007 »
Offline tautech
« Reply #21 on: July 23, 2019, 02:28:39 am »
Projectors ?
Yeah I dunno why it's still in use either as a better solution is an inbuilt webserver where the display can be ported to any LAN connected display, PC or laptop.
Offline TK
« Reply #22 on: July 23, 2019, 03:00:59 am »
Optional serial decoding???  Seriously???
« Reply #23 on: July 23, 2019, 05:40:21 am »
Just the input basics > channel selection, input gain/attenuation, Position etc
and whatever else can be squeezed in for battlers on food and gear rationing   :D
This assures faster setups (IMVHO), no brainer tweaks, less mistakes, bumps, accidental shared control swipes, and crossed fingers etc
There's always going to be menu work with any decent DSO,
but at least have four simple dedicated channel control strips on a 4 ch DSO
and separate controls and socket for external triggering (another 'shared' -sacrifice a channel- dislike   :rant:)
It can be done, I have a 4 ch Siglent kicking around that has this, and the only reason i didn't go the Rigol,
both were same-ish dollars IIRC
Online Fungus
« Reply #24 on: July 23, 2019, 06:15:26 am »
It actually isn't:
https://en.wikipedia.org/wiki/USB_hardware#Durability
I'm sure we all have a loose USB-B connector somewhere, eg. on an Arduino.
