Author Topic: New TRMS Uni-T UT139C DMM is available now  (Read 148511 times)
Offline WytnuclsTopic starter
« on: July 28, 2013, 08:43:25 pm »
The new 6000 count UT139C DMM is now coming to market. It felt pretty well built, when I handled a sample two months ago, before its official release.
It seems reasonably priced too, for a TRMS meter with temperature measurement,a backlit LCD, NCV and optional clamp meter connection. It sells for about 50$ plus delivery cost on eBay (free delivery for the US).
At first glance, it looks like at least one HRC fuse is accessible from the 2 AA battery compartment. It is marked as CAT III 600V.
http://www.ebay.com/itm/UNI-T-UT139C-True-RMS-Digital-Multimeters-AC-DC-with-Temperature-Auto-Range-/181179994103?pt=LH_DefaultDomain_0&hash=item2a2f2b4ff7
« Last Edit: July 28, 2013, 09:29:37 pm by Wytnucls »
Online edavid
Re: New TRMS Uni-T UT139C DMM is available now
« Reply #1 on: July 28, 2013, 08:50:31 pm »
I don't get it, why would you buy this instead of a UT61E?
Online Monkeh
« Reply #2 on: July 28, 2013, 08:53:30 pm »
Temperature, clamp, backlight, NCV...
Counts aren't everything.
« Reply #3 on: July 28, 2013, 09:28:39 pm »
It also has VFC (Variable Frequency something?), Max/Min, auto power off, 3V diode test and possibly, proper input protection.
The rubber holster looks like it is removable.
« Last Edit: July 28, 2013, 09:35:18 pm by Wytnucls »
Offline BillyD
  • Country: ie
« Reply #4 on: July 28, 2013, 09:48:55 pm »
what clamp does it have? A current clamp?
Offline Lightages
  • Canadian po
« Reply #5 on: July 28, 2013, 09:49:20 pm »
The VFC function is basically a low pass filter to to remove noise caused by variable frequency motors/drives. It they took input protection seriously this time this would be a nice meter for the money. If they skimped and lied bout the rating again then this would be a potential bomb ready to go off in your hand.
« Reply #6 on: July 28, 2013, 10:04:49 pm »
I think it is compatible with the new UT221 and UT222 clamp meters, both TRMS AC and DC.
I'm not sure if they are available yet.
« Last Edit: July 28, 2013, 10:17:42 pm by Wytnucls »
« Reply #7 on: July 28, 2013, 10:26:01 pm »
There is hope, look at the picture ;)
Offline chibiace
« Reply #8 on: July 28, 2013, 10:55:32 pm »
are you sure thats a clamp icon on the voltage jack.
He Who Controls The Spice Controls The Universe
Online Monkeh
« Reply #9 on: July 28, 2013, 11:02:08 pm »
Yes. It supports an external clamp with a 60A range, 10mV/A.
Offline true
  • INTERNET
« Reply #10 on: July 28, 2013, 11:57:22 pm »
If it's like the UT136 the NCV is 220V only. Need to find a manual...
Online Monkeh
« Reply #11 on: July 29, 2013, 12:13:21 am »
Not their fault certain countries are behind the times.
Offline true
  • INTERNET
« Reply #12 on: July 29, 2013, 12:15:11 am »
Thanks for being helpful and posting the manual.
The meter I keep in my work bag is sensitive starting at 24V, but does trigger below that so in addition to outlets and power cords it's handy for quick checks to see if alarm and lighting panels are powered.
« Last Edit: July 29, 2013, 12:16:56 am by true »
Online Monkeh
« Reply #13 on: July 29, 2013, 12:15:45 am »
I'm sorry, but I don't speak Chinese. Perhaps you'd like to go have a look?
I think we can reasonably expect it to be set for 230V.
Offline true
  • INTERNET
« Reply #14 on: July 29, 2013, 12:18:41 am »
Why? As I wrote above, it's possible to have a wider range than just line voltage. Additionally, the basic meter or stick NCV that trigger at ~100V will typically also trigger at higher voltages.
Online Monkeh
« Reply #15 on: July 29, 2013, 12:20:18 am »
Trigger at higher levels, yes, and be violently oversensitive around lower voltages and coupled voltages in countries which don't use 120V distribution.
Offline true
  • INTERNET
« Reply #16 on: July 29, 2013, 12:32:33 am »
I really don't know why you want to argue this so much, it's like you feel personally attacked by this or something. Over a feature to quickly check if power is present on a power line or outlet. Sorry for upsetting you so strongly over such a simple question; I didn't know there would be such animosity when the possibility of voltages lower than 230V are brought to discussions.
I'll just wait for someone who buys one to post what the manual says.
Online Monkeh
« Reply #17 on: July 29, 2013, 12:38:10 am »
Not so much..
My sincerest apologies for offending you with a joke.
Offline don.r
« Reply #18 on: July 29, 2013, 01:32:49 am »
Given that the UT136D only does 230V for NCV, its most likely true here as well. Remains to be confirmed, however.
Offline true
  • INTERNET
« Reply #19 on: July 29, 2013, 01:44:29 am »
Yeah, that is what I originally wrote... :( I am concerned because for what I do it would be helpful. My PM55A works fine but takes a while to "boot" :(
Offline don.r
« Reply #20 on: July 29, 2013, 02:19:56 am »
Ooops... must have skipped past that bit. Sorry. It would have been good, even if they offered a D or E model with 120V NCV instead of 220V.
« Reply #21 on: July 29, 2013, 05:31:21 am »
NCV is good for the States too on this one; it triggers at any voltage above 100V RMS.
« Last Edit: July 29, 2013, 05:35:52 am by Wytnucls »
Offline Electro Fan
« Reply #22 on: August 16, 2013, 12:29:41 am »
Anyone actually see/use the 139C yet?
« Reply #23 on: August 16, 2013, 12:39:42 am »
I held a sample in the Uni-T office before the release, but didn't have time to test it properly. It felt reasonably well made, but the low count (6000 max) put me off a bit.
Here is a picture of the meter I took at the time, while in China:
Offline Fsck
  • sleep deprived
« Reply #24 on: August 16, 2013, 12:55:41 am »
if you had one in your hand, should've distracted the workers and taken it apart.
"This is a one line proof...if we start sufficiently far to the left."
