1 more error.
Without a signal, vertical division is 200mV 1x and the trigger level is set to 200mV, the trigger is single.
Oh, and the trigger has a falling edge.
At 5-50nS, if you press a STO/RET button, it triggers nothing...
At 100nS, if I can see it well, but again at 200nS.
CH1 AC/DC is not affected.
If you succeed in pressing the RUN state, it is already stably waiting for the signal.
It is possible that the button is pressed twice.
But then why only for falling triggering?
Interesting.
If the baseline is in the upper half or right in the middle with the ORIG button, and the trigger arrow is in the upper part, the error will occur.
If I just put the trigger below the center line, there is no error.
If I move the base line below the center line, the error disappears.
