Author Topic: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)  (Read 128350 times)
Offline Evi
  • Country: ru
Re: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)
« Reply #250 on: August 03, 2023, 03:19:34 pm »
Is this topic about the general?
Offline BillyO
« Reply #251 on: August 03, 2023, 03:24:06 pm »
Go find someone else to fight with.  :box:
There have been many other scopes mentioned in this thread as well as heaps of general statements.
I realize English is not your first language, but that means you must try a bit harder to make sure your intent is properly understood.
Offline ru_tash
« Reply #252 on: August 03, 2023, 03:41:02 pm »
Sorry, I recheck terminator it was bad connection (in fact all measurements were done with 1Mohm)
Retest with properly contacted.
Freq(Mhz)      1     3   10   20   40   50   60  70   80  100  110 120 130 150
Ch(Vpp,mV)   142 142 142 144 148 150 154 158 165 168  177 182 186 196
It really seems strange that the amplitude would increase with frequency.  Something is not quite right.
let's wait someone else repeat BW test with his DPOX180H.
Offline ru_tash
« Reply #253 on: August 03, 2023, 03:52:54 pm »
Bravo! Now try this on DPOX180
You were not specific about which scope you meant.  It sounded like a general statement.
In any case a sine wave sweep or rise time analysis should work just fine on the DPOX180 to determine it's bandwidth.
perhaps he meant to say that some cheat/cheap oscilloscopes artificially "reconstruct" sine wave based on prediction (or without it) on higher side of BW.
Offline walshy007
« Reply #254 on: August 03, 2023, 04:27:17 pm »
I can do that, my DPOX180H came in the mail last week. I figured it would be a cheapish toy but if I could learn it's limits by comparing it to my 300mhz rigol it could be useful for portable use.
I'll set it up the sig gen and be back in a bit with a couple numbers for comparison.
The following users thanked this post: SanFable
Offline walshy007
« Reply #255 on: August 03, 2023, 05:42:34 pm »
My results
The signal generator used was an ancient "turn the dial" type going to a coax output fed directly into the scope.
The amplitude dial being adjusted until the rigol read the number I wanted to check on. Coax then fed to DPOX180H, and when done back to rigol to double check what it says. All measurements peak to peak.
Freq (mhz)3.5306090130
Rigol1.00v1.00v100mv1.00v100mv
DPOX180H1.00v0.984v109mv1.15v135mv
The upwards at higher frequencies trend matches ru_tash.. which is.. weird. Definitely not just them though.
The following users thanked this post: BillyO, artik
Offline BillyO
« Reply #256 on: August 03, 2023, 06:01:57 pm »
Yeah, very strange.
Thanks for looking into it guys. :-+
Offline IconicPCB
« Reply #257 on: August 04, 2023, 11:42:49 am »
If a square wave is used to check the bandwidth then upward swing is to be expected since the effective sampling rate of the front end drops off with increase of input frequency.
Now consider the fourier coefficients of a square wave and the amplitude of fundamental versus RMS/PEAK .
As signal frequency goes up, sampling rate drops down with respect to the fundamental.
This results in a  loss of higher order harmonics and so fundamental becomes more prominent.
I seem to recall 1,4 is the multiplier of fundamental. And then again it is possible the front end of the input stage may be slightlyover compensated resulting in a complex pole pair and gain peakines.
While messers Nyquist and Shannon assert  minimum sampling rate of two and the toy scopes offer a sampling rate of fivish... a real man;s scope should offer a sample rate of typically tenish for good waveform reproductive fidelity...
Try doing bandwidth measurements with a single channel active and then repeat with both channels active ( to see effect of reduced sampling rate)
« Last Edit: August 04, 2023, 11:44:52 am by IconicPCB »
Offline Evi
  • Country: ru
« Last Edit: August 04, 2023, 12:45:11 pm by Evi »
Offline Rooster Cogburn
« Reply #259 on: August 04, 2023, 12:57:13 pm »
I have found a new video showing a new bug/crash of this device when using the usb function. Try on your units to see if it happens.
https://youtu.be/NLNTrn9KVrk
I just got my DPOX180H and it seems to have the exact issue from the video :-[ The scope seems to work and I can connect it over USB on my Mac and the files/directory structure is there but as soon as I either try to upload a firmware file or download any screenshots or waveforms the unit freezes and no copy takes place. I tried on my Linux laptop and the volume never even mounts. I tried resetting all settings and formatting the storage no change. When I back out of the USB screen I get the same effect as in the video where all the text is missing.
Any ideas?
« Last Edit: August 04, 2023, 01:24:14 pm by Rooster Cogburn »
Online Aldo22
« Reply #260 on: August 04, 2023, 01:07:57 pm »
https://youtube.com/shorts/dXxeHHcKgRU?feature=share
Better once to see.
That doesn't look too bad.
In single-channel mode, however, it only becomes a sine wave at 60MHz, doesn't it?
Offline Evi
  • Country: ru
« Reply #261 on: August 04, 2023, 01:17:55 pm »
Do not mix it with ZEEWELL
It does not
Online Aldo22
« Reply #262 on: August 04, 2023, 02:35:02 pm »
It does not
That's hard for me to believe.
With the Zeeweii DSO2512G you can calculate it pretty accurately.
Single channel, not overclocked: 96MHz bandwidth.
So you can still see the "3rd harmonic" at 96/3 = 32MHz (Before it looks like a sine).
Overclocked 120/3 = 40Mhz and half of it in dual channel mode (16 and 20MHz respectively).
Is that really different with the DPOX180H?
« Last Edit: August 04, 2023, 02:37:50 pm by Aldo22 »
Offline Evi
  • Country: ru
« Reply #263 on: August 04, 2023, 02:53:13 pm »
Zeeweii in single channel mode works in alternate ADSs mode
when both ADC channels digitizes 1 input. So, the sample rate twiced.
DPOX does not has this mode.
The following users thanked this post: RAPo, Aldo22
Online Aldo22
« Reply #264 on: August 04, 2023, 03:38:25 pm »
So this is a fake? See 50Mhz screenshot.
Can somebody confirm this?
« Reply #265 on: August 04, 2023, 06:08:29 pm »
I did investigate the USB issue a bit further. I tried a different cable and different ways of accessing the storage. Same results. On Mac it always freezes on transfer and on Linux I can't even mount anything, I just see the device on lsusb.
I asked a friend with a Windows machine and there it worked immediately. We were able to update the device with the v30 firmware posted here. Still, USB doesn't work for me with that firmware either but at least I now have the bugfixes.
Never seen a USB mass storage device before that's picky about the OS/computer, seems like the USB implementation is completely broken. Would be great if they could fix that :-\
« Reply #266 on: August 04, 2023, 08:23:19 pm »
I've been playing around with the scope all evening, sorry in advance for all the dumb questions:
- On timebases over 50ms the measurements disappear and the scope switches to rolling mode, is there any way to keep measurements for longer timebases?
- Can you reliably/instantly set one of the vertical cursors to 0? Just because of the peculiar way cursors work on this scope setting one to zero is the only way to see an absolute position for cursor two
- Does somebody find the FFT function useful? Maybe it's just me but is this basically just a gimmick?
- Is there any way to do channel arithmetic like to simulate a differential probe?
- Does anybody else have the USB mode issue I and the fella from the YouTube video have? Did anybody here try the USB connection with Linux/Mac?
Thanks :D
Online RAPo
« Reply #267 on: August 05, 2023, 07:49:25 am »
Not that I know.
you can get some info (eg is there a harmonic) but basically it is a gimmick.
No
No problems under windows, no problems under WSL Ubuntu, no problems on a Zorin OS.
« Reply #268 on: August 05, 2023, 08:49:55 am »
Thanks!
So I tried the USB mode on two Macs and two different Linux systems (Mate & Ubuntu) and neither worked. A friend's Windows laptop worked perfectly. FNIRSI Support says apparently only Win10 is supported. I don't think I've ever seen an USB storage device that only works on one OS let alone fails in such a spectacular fashion when connected to another OS. I guess this was only tested on like one computer with one specific USB stack or one specific USB host controller chip. I wouldn't have much confidence this even keeps working on any new Windows version/updates.
« Last Edit: August 05, 2023, 09:00:06 am by Rooster Cogburn »
« Reply #269 on: August 05, 2023, 09:05:36 am »
Do you keep the scope plugged into USB power at all times when it's sitting on your bench? I noticed once it's charged the power button keeps alternating between red/green every couple of minutes. I'd want to preserve battery health as much as possible and wonder if it's best to only plug in the scope when using it or when it's empty or to just keep it on a USB charger at all times.
Online RAPo
« Reply #270 on: August 05, 2023, 09:12:14 am »
No when I am using the scope for measuring there is no USB connection. Only for charging and transferring files the usb-cable is in.
Online Aldo22
« Reply #271 on: August 05, 2023, 10:49:51 am »
@RaPo: Could you please confirm this?
You own a DPOX and you thanked Evi for his posting.
I still can't believe this as Fnirsi explicitly states differently.
Can you test with a 60MHz square wave with the second channel switched off?
For example, a NanoVNA can generate 60MHz square.
Offline Evi
  • Country: ru
« Reply #272 on: August 05, 2023, 11:52:13 am »
Thomas the unbeliever
Online Aldo22
« Reply #273 on: August 05, 2023, 12:14:59 pm »
I do believe, I just don't know who! :-DD
Online Aldo22
« Reply #274 on: August 05, 2023, 12:50:24 pm »
No, really. Fnirsi shows this screenshot and you say this is not possible with the DPOX180H @50MHz.
What should I believe?
