Author Topic: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)  (Read 128358 times)
Online RAPo
Re: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)
« Reply #225 on: July 28, 2023, 05:22:03 am »
Not that I am aware of.
There is a logic analyser called LA-104 in miniscope format (with a bandwidth of 100MHz,4 channels) for around $80, that can be used without a PC.
But I think you are better of with a USB device such as Kingston LA1010. There you have 16 channels, a 100MSa/s sampling rate and bandwidth just below 60MHz.
Another question:
I was looking again at similarly priced scopes and was wondering if there's anything around the hundred bucks mark that includes any protocol decoding?
Online dietert1
  • Country: br
    • CADT Homepage
« Reply #226 on: July 28, 2023, 05:49:57 am »
Another kind of device is a handheld like the Aneng AOS02 with only one scope channel but a built in DVM, with about half the price of the DPOX180H. Don't know which one is more useful. The Aneng includes a temperature probe and a current shunt. It also measures resistance, capacitance and frequency. Don't know how serious is their 10 MHz scope bandwidth spec.
Regards, Dieter
The following users thanked this post: Markus2801A
Online RAPo
« Reply #227 on: July 28, 2023, 07:15:45 am »
The ANENG AOSO2 is a rebranded Zoyi ZT-702S.
Both are one channel.
I have the 702S. I like the multimeter part. The scope function has an essential missing measurement: dutycycle, is about 10MHz.
It is not a logic analyzer and has no decoding functionality.
It seems that a 2-channel,50MHz Zoyi ZT-703S is coming up. That would be better comparable to the FNIRSI/Zeeweii, but it also has no protocol decoding.
Offline plazma
    • Homepage
« Reply #228 on: July 28, 2023, 07:59:39 am »
I asked about the signal generator offset bug by email. They replied a new firmware will fix the issue.
The following users thanked this post: ru_tash, RAPo, Andy620
Online Aldo22
« Reply #229 on: July 28, 2023, 09:19:53 am »
The AOS02/ZT-702S is better as a multimeter and the DPOX180H is by far better as an oscilloscope, as the latter is not a scopemeter and thus has no multimeter function, but does have a signal generator.
Actually, it makes no sense to compare the two.
Online Aldo22
« Reply #230 on: July 28, 2023, 10:27:41 am »
If you want to start with the topic and 24MHz / 8 channels are enough for the moment, maybe one that costs as much as a pack of cigarettes does the job:
https://www.aliexpress.com/item/1005001417581550.html
With the "PulseView" software, this is already quite useful in the Arduino area, for example.
S.a. https://learn.sparkfun.com/tutorials/using-the-usb-logic-analyzer-with-sigrok-pulseview/all
« Last Edit: July 28, 2023, 10:29:55 am by Aldo22 »
Online RAPo
« Reply #231 on: July 28, 2023, 11:07:00 am »
I have had a bad experience with these chinese devices: connections got loose. Then I came to my senses and ordered a bit more expensive Kingston and working with that happily after (still looking for a cheap that can also do hardware triggering instead of software triggering)
Online Aldo22
« Reply #232 on: July 28, 2023, 11:28:08 am »
Well, for the price you don't have to think twice.
I don't know what "Rooster Cogburn" needs exactly.
To get an idea of what the topic is about, these are quite OK.
If you know exactly what you want, you buy a better one.
Offline ru_tash
« Reply #233 on: July 28, 2023, 12:41:17 pm »
from my not huge experience - better get two or three devices lower grade than one but hi-end.
you would always afraid to probe high voltage parts or unknown circuit with thousands dollar masterpiece  :)
Online RAPo
« Reply #234 on: July 28, 2023, 02:55:44 pm »
I had the same thoughts initially.
Sure, I'm not spending an amount above $100. But I must say that working with the LA1010 and 16 channels is much easier than the Chinese device.
But indeed, for a tryout or use once a month the chinese device is an option.
Offline ru_tash
« Reply #235 on: July 29, 2023, 04:05:14 pm »
can somebody try to adjust system setings->transparent menus?
I see that it is working only during adjusting (percents running to zero and grid disappearing) but actually no effect to menu after quit.
Online RAPo
« Reply #236 on: July 29, 2023, 05:04:29 pm »
If you adjust this setting to a specific value and quit, the next time you open a menu, it remembers the setting.
Offline ru_tash
« Reply #237 on: July 30, 2023, 03:29:08 am »
can you try to set transparent menu to 0%, will you still see grid on the screen?
« Last Edit: July 30, 2023, 04:48:18 am by ru_tash »
Offline SanFable
« Reply #238 on: August 02, 2023, 10:33:17 pm »
Hello,
I have spent 2 days looking for correct bandwidth tests* of DPOX180H and still didn't found test with terminator, anyone? is it worth anything?
I'm looking for my first oscilloscope up to ~200$
Fnirsi DPOX180H vs Owon HDS2102 vs Hantek dso2c10 (then upgrade to 150Mhz)
which should be best?
I need something universal,
I might try to check car ignition coils or other car stuff
then mainly I will use it with repairing low voltage electronics
I love small form factor, but Im afraid of 2,8'' or 3.5'' LCD
I think that measuring up to 50Mhz in a "good way" would be great
the DPOX180H GUI seems amazing compared to others?
*btw, why there are so many tests to max oscilloscope bandwidth? I mean if its 100Mhz people test it at 100Mhz, they don't know about Shannon sampling theorem? or something changed with DSO?
Offline BillyO
« Reply #239 on: August 02, 2023, 10:47:53 pm »
Hello,
I agree.  I have also asked but have received no real response.  I guess the people with this scope either do not know how to test for bandwidth, don't care or don't have the right equipment.
From my perspective, you assume the vendor is telling only one lie.   In this case, since the claimed sample rate is marginally fine for the claimed BW I would test for BW first.  Then if it fell significantly short of BW claims I'd then check the sample rate to see if they are also lying about that.  From what we have seen from FNIRSI in the past I am inclined to assume the BW is 60MHz or less.  In which case, that's all you get and a 500Ms/s sample rate is .. meh. :-//
Offline ru_tash
« Reply #240 on: August 03, 2023, 07:05:30 am »
Freq(Mhz)      1     3    10   20   40  62   70   80  100  120  150
Ch(Vpp,mV)   286 284 284 282 273 250 262 277  264  248  228
terminator 50ohm (correction - terminator was not connected properly so load was 1Mohm)
62Mhz - first minimum
« Last Edit: August 03, 2023, 10:40:38 am by ru_tash »
The following users thanked this post: SanFable
Offline SanFable
« Reply #241 on: August 03, 2023, 08:11:37 am »
terminator 50ohm
Finally, thanks :)
Im trying to understand,
-13dBm = 142mV peak-to-peak
dpox180h Vpp readings are far away from this value?
Offline ru_tash
« Reply #242 on: August 03, 2023, 08:44:33 am »
terminator 50ohm
Finally, thanks :)
Sorry, I recheck terminator it was bad connection (in fact all measurements were done with 1Mohm)
Retest with properly contacted.
Freq(Mhz)      1     3   10   20   40   50   60  70   80  100  110 120 130 150
Ch(Vpp,mV)   142 142 142 144 148 150 154 158 165 168  177 182 186 196
« Last Edit: August 03, 2023, 08:46:24 am by ru_tash »
The following users thanked this post: BillyO, SanFable
Online Aldo22
« Reply #243 on: August 03, 2023, 09:24:39 am »
So it's approaching +3dB instead of -3dB at @150MHz?
Offline ru_tash
« Reply #244 on: August 03, 2023, 12:46:43 pm »
not so obvious, when input 1Mohm voltage-frequency response is not linear.
Offline Evi
  • Country: ru
« Reply #245 on: August 03, 2023, 02:25:34 pm »
Testing with sinusoidal signal is sence less,
 because above 30MHz scope FW converts any signal to sinusoidal.
Offline BillyO
« Reply #246 on: August 03, 2023, 02:45:52 pm »
What are you talking about?
Sine wave sweep is one of the preferred ways to determine BW.  The other is to measure fastest rise time.
If your scope is turning everything to a sine wave @ 30MHz, then it's BW is much less than 30MHz
Below is a square wave at 140MHz.  Other than a little ringing it's not looking much like a sine wave.
« Last Edit: August 03, 2023, 02:48:58 pm by BillyO »
Offline BillyO
« Reply #247 on: August 03, 2023, 02:55:27 pm »
It really seems strange that the amplitude would increase with frequency.  Something is not quite right.
Offline Evi
  • Country: ru
« Reply #248 on: August 03, 2023, 03:10:22 pm »
[size=78%]Quote from: BillyO on Today at 08:45:52[/size]
Bravo! Now try this on DPOX180
« Last Edit: August 03, 2023, 03:12:03 pm by Evi »
Offline BillyO
« Reply #249 on: August 03, 2023, 03:13:49 pm »
You were not specific about which scope you meant.  It sounded like a general statement.
In any case a sine wave sweep or rise time analysis should work just fine on the DPOX180 to determine it's bandwidth.
