Author Topic: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)  (Read 123781 times)
Online RAPo
Re: New toy(?) scope Fnirsi DPOX180H, claimed 180MHz/500MSps (May 2023)
« Reply #175 on: July 25, 2023, 05:35:50 pm »
FNIRSI replied with:
Hi, dear friend, thank you very much for your feedback;
I will submit this suggestion; we will continue to optimize and release new firmware in the future;
thank you
@RAPo
hello,
as you got in contact with Fnirsi support, could you suggest them the following:
1. Is it possible to automatically save current settings on power off?
2. Internal generator has significant DC offset. Do you plan remove it?
3. In current FW (3.0) it not possible to see FW version.  Maybe show it on startup screen?
Offline ru_tash
« Reply #176 on: July 26, 2023, 04:20:14 am »
I don't think it is a good idea.
Offline Evi
  • Country: ru
« Reply #177 on: July 26, 2023, 06:58:01 am »
All serious scopes do it
Online RAPo
« Reply #178 on: July 26, 2023, 07:41:37 am »
Nope, all serious scopes give you the option to do it ;-)
Online Aldo22
« Reply #179 on: July 26, 2023, 07:50:21 am »
DSO2512G does it and I think it's a very good idea.
This is one of the reasons why working with the Zeeweii is quite pleasant.
A very fast "Auto" function is another reason.
Offline ru_tash
« Reply #180 on: July 26, 2023, 11:51:37 am »
lets assume that you enter such mode where device is not running normal, for now you can power off-on, but if this will be saved you go on circle.
Offline ru_tash
« Reply #181 on: July 26, 2023, 11:59:12 am »
I have two quite serious oscilloscopes (RIGOL DS2072A and FLUKE PM3384A)  both of them have preinstalled settings, none of them save on power off.
Offline ru_tash
« Reply #182 on: July 26, 2023, 12:06:29 pm »
have you tried to use DPOX180H on 10-20-50s timebase? I think it is quite useless especially on 50s, device not responding properly.
Offline Evi
  • Country: ru
« Reply #183 on: July 26, 2023, 12:18:00 pm »
Quote from: ru_tash on Today at 05:59:12
>Quote from: Evi on Today at 00:58:01
RIGOL DS2072A  does save settings
Online Aldo22
« Reply #184 on: July 26, 2023, 12:25:23 pm »
I see what you mean, but I've had the DSO2512G for 7 months now and nothing like this has ever happened (That's another reason why I like the Zeeweii).
If it did happen (unlikely), then I could probably remove the battery connector.
« Last Edit: July 26, 2023, 12:27:13 pm by Aldo22 »
Offline ru_tash
« Reply #185 on: July 26, 2023, 01:16:07 pm »
it depends on setting, and this is configurable. i don't mind if in DPOX180H will have same feature - but this will change menu stucture.
Online RAPo
« Reply #186 on: July 26, 2023, 03:14:13 pm »
Agreed, it was not my request I'm only the messenger.
Online RAPo
« Reply #187 on: July 26, 2023, 03:16:21 pm »
nope battery connector will not help, there has to be a way (restore factory settings or something like that) to break out the loop.
Online RAPo
« Reply #188 on: July 26, 2023, 03:19:27 pm »
Well, there is already a menu option (Menu|Systemsettings|Save current configuration) to save the current settings for restoring at start-up. One extra item (Save settings automatically when powering off) is not a big deal.
Offline ptluis
  • Country: pt
« Reply #189 on: July 26, 2023, 04:02:06 pm »
hello is dpox180h able to measure the amplitude of a spike using cursors like i did (points A - B) with the dso2512g? and return the correct dY value? see picture attached.
« Last Edit: July 26, 2023, 04:11:05 pm by ptluis »
Offline ru_tash
« Reply #190 on: July 26, 2023, 04:22:57 pm »
would be like this, CH2
The following users thanked this post: ptluis
Offline Rooster Cogburn
« Reply #191 on: July 26, 2023, 05:32:33 pm »
Is this the issue discussed earlier where each cursor is for a different channel? I don't see a delta measurement?
Offline ru_tash
« Reply #192 on: July 26, 2023, 05:46:43 pm »
actually it is delta.
the cursors behavior I explain to myself the following: both cursors work for both channels simultaneously, so system calculates delta via multiplying vertical sensitivity of each channel with geometrical distance between cursors.
Online RAPo
« Reply #193 on: July 26, 2023, 05:49:04 pm »
Thats correct. The cursors at the DPOX are different than the cursors in the Zeewei.
For the DPOX it is stated (bold is mine):
The measurement principle of the cursor is to measure according to the vertical sensitivity of the channel.
Therefore, when measuring, it is necessary to measure the voltage cursor of the channel separately to obtain an accurate value.
V1V2 is the vertical sensitivity set according to channel one and channel two; to measure the voltage value of the range selected by the cursor
So you cannot subtract the cursor's values.
See the image where the same  5Vpp sine signal is applied to both scopes.
« Reply #194 on: July 26, 2023, 06:02:31 pm »
But the channel 2 cursor is relative to the channel 2 waveform, which doesn't even exist in this example. So could I basically have two channel 1 cursors by having the vertical scale and vertical offset of both channels identical, but I still need to subtract them myself?
Also are the cursors not color coded to the channel, what is 'S' here?
Online Aldo22
« Reply #195 on: July 26, 2023, 06:11:54 pm »
So is it true that the DPOX doesn't have numeric feedback (voltage level) of the absolute position of the cursors?
For example, if I want to set the cursor at 90% of VTop, do I have to do it visually and approximately?
Online RAPo
« Reply #196 on: July 26, 2023, 06:16:27 pm »
And that's why I state that the cursor function is not right implemented at the Fnirsi scope.
You mean the  S in the CSR at the right top of the letter S at the lower vertical cursor?
CSR = all direction keys only control the cursor
S at the lower cursor line: means, the lower cursor bar is selected to move (press auto in csr-mode to switch to the upper cursor line).
Cursor lines are always green and not associated with channel colors.
« Last Edit: July 26, 2023, 06:19:43 pm by RAPo »
Online RAPo
« Reply #197 on: July 26, 2023, 06:17:19 pm »
correct
« Reply #198 on: July 26, 2023, 06:19:39 pm »
Sorry, Ok, now I finally get it, it shows the delta between the cursors but for each channel. That is really weird, especially since as you point out there's no way to get an actual value for the cursor. I guess you could place one cursor on 0? Is that how the cursors also work horizontally?
« Last Edit: July 26, 2023, 06:23:58 pm by Rooster Cogburn »
Online RAPo
« Reply #199 on: July 26, 2023, 06:23:10 pm »
Ok now I finally get it, it shows the delta between the cursors but for each channel. That is really weird, especially since as you point out there's no way to get an actual value for the cursor. Is that how the cursors also work horizontally?
Nope there is only one time base so for horizontal cursors both the time difference (T) and the frequency (F=1/T) are displayed.
But you can only move the cursor lines, not set it to a value.
