nothing groundbreaking, but as I was just busy replacing the motherboard of 2 6100A's (with some from Kontron), I though I'd publish the SDVO/LCD pinout, for those who'd need to make their custom LVDS cable, too...
I used a 20-wires pre-crimped cable, but some other LCD's/mainboards may require a different number of wires.
the LCD connector on the front panel board of the (A) series is compatible with a Hirose DF19-20 connector, the backlight (inverter) connector (on the cable) is JST S5B-PH 5-pin female connector (I didn't use it, and soldered the power supply lines from the motherboard onto the wires directly)
