Author Topic: SPD1168X and SPD1305X Siglent PSU's  (Read 22668 times)
Offline 2N3055
  • Country: hr
Re: SPD1168X and SPD1305X Siglent PSU's
« Reply #50 on: September 18, 2019, 09:28:47 am »
Was there ever any resolution to this transient behaviour ??
What transient behavior? Could you be more specific please?
Offline tautechTopic starter
« Reply #51 on: September 18, 2019, 09:44:23 am »
Study posts #46 and 48.
« Reply #52 on: July 12, 2020, 10:21:38 am »
Hello, I know this is an old thread but I am a beginner and I was considering the SPD1305X for my first bench power supply. From what it looks like it was determined that this supply doesn't have any significant voltage overshoot, is that correct? Near the end of the thread I couldn't tell if that was the final verdict, thanks.
Welcome to the forum.
Yes they are well behaved.
To add to some screenshots earlier in the thread, 2 more but with the output loaded with just a 10x probe.
SPD1305X Version 2.1.1.8 firmware (2019-04-29)
Power ON and output OFF (default)
Channel ON set to 5V 5A
Offline rernexy
« Reply #53 on: December 14, 2020, 02:59:05 am »
Does the SPD1168X have programmable over-voltage and programmable over-current protection/cutout? I'm reading the user manual for it, and it doesn't mention it as far as I can see. This is a feature my QL355P has, so I'm comparing that to candidates for a 2nd supply.
« Reply #54 on: December 14, 2020, 03:30:33 am »
Not programmable AFAIK only a set point for reverse OV that is specified as 22V+2V for SPD1168X.
P18
https://siglentna.com/wp-content/uploads/dlm_uploads/2018/05/SPD1000X_UserManual_UM0501X-E02A.pdf
The following users thanked this post: rernexy
« Reply #55 on: January 27, 2022, 07:21:14 am »
New firmware for SPD1168X and SPD1305X models.
Version V2.1.1.9
585 KB
https://int.siglent.com/upload_file/zip/firmware/Power_Supply/SPD1168X_V2.1.1.9_EN.zip
https://int.siglent.com/upload_file/zip/firmware/Power_Supply/SPD1305X_V2.1.1.9_EN.zip
Release notes
Added the OCP function (Long push “Fine” to enter or exit OCP function)
Fixed a command stop character bug
The following users thanked this post: TheDefpom, plurn, Algoma
Offline Algoma
« Reply #56 on: February 13, 2022, 04:49:51 pm »
EasyPower gave me an "Invalid update" message with the update. Re-applied v2.1.1.8 as a test, then v2.1.1.9 updated as expected.
Nice to have an OCP option when needed, I was thinking about missing that feature a few weeks ago. Being firmware driven, CC Mode kicks in well before OCP triggers in about 300ms. Both CC and OCP settings remain active at their set points. Worked well to protect a simple Red LED under reasonable conditions.
The following users thanked this post: plurn
« Reply #57 on: April 17, 2023, 10:33:18 am »
Offline Mahagam
« Reply #58 on: March 20, 2024, 10:33:17 pm »
Release notes
Do you know if there is an corresponding SCPI command for this setting?
« Reply #59 on: March 20, 2024, 11:08:53 pm »
Release notes
Not in the SPD1000X manual but found in the SDP5000X manual on P82/82
https://int.siglent.com/u_file/download/22_06_28/SPS5000X_Usermanual_E02B.pdf
Please report success or otherwise.
Offline Mahagam
« Reply #60 on: March 21, 2024, 07:46:06 pm »
Nothing common with SPD5000 series commands.
For SPD1168X you can set/get voltage/current with fully formatted string e.g.:
ch1:volt 5.000
ch1:volt?
5.000
ch1:curr 0.5
ch1:curr?
0.5
but you cannot set/get ocp in this way, no ch1:ocp 2.345 will be accepted.
But!!!
you can just set/get voltage/current/ocp via simplest format! :
volt 4.534
volt?
4.534
curr 0.6
curr?
0.6
ocp 2.0
ocp?
2.0
*idn?
Siglent Technologies,SPD1168X,SPD13DCD7R1985,2.1.2.11,V2.0
As you can see, I have SPD1168X with HW version 2.0 and fw version 2.1.2.11
Offline Mahagam
« Reply #61 on: March 22, 2024, 08:27:50 am »
I still have a question about SPD1168X. I have siglent 4 devices (SDS2104X+, SPD1168X, SDG2042X, SDM3055). Everything is connected to a LAN, but only 3 devices can be detected via VXI-11.
For the SPD1168X I have to enter IP address manually. Is there any way to find SPD online?
