Some quick facts/findings from the first I've seen of these:
2s boot time.
Quiet smart fan. 80mm. At no time with the following tests and loads did the fan speed increase.
2 sets of 650mm leads with croc clips, one set with open lug terminals and the other with molded banana plugs.
Output enable soft key driving an output relay. Note, the relay is only bought into ON switching function at voltages above 4.4V settings below which silicon is doing the switching.
19mm terminal spacing.
Overshoot test, high current.
12V set, 8A set.
12V halogen auto lamp, 5A draw.
DSO SDS1104X-E, 10x stock probe, Normal triggering.
![](https://www.eevblog.com/forum/testgear/new-spd1168x-siglent-psu/?action=dlattach;attach=478610)
Ripple check.
Load as above.
![](https://www.eevblog.com/forum/testgear/new-spd1168x-siglent-psu/?action=dlattach;attach=479366)
Overshoot test, low current.
4.4V set, 8A set
Red LED with 1k current limit resistor.
5mA displayed as drawn.
![](https://www.eevblog.com/forum/testgear/new-spd1168x-siglent-psu/?action=dlattach;attach=478745;image)
Ripple check.
Load as above.
![](https://www.eevblog.com/forum/testgear/new-spd1168x-siglent-psu/?action=dlattach;attach=479360)
More checks and tests later.
