Author Topic: SPD1168X and SPD1305X Siglent PSU's  (Read 22239 times)
Online tautechTopic starter
« on: February 13, 2018, 10:16:49 pm »
Initially from unofficial whispers....
16V @ 8A with remote sense.......
New model added Oct 18
30V @ 5A
5 digit Voltage, 4 digit Current Display, Minimum Resolution: 1 mV/1 mA
Ripple and noise:≤ 350 uVrms/3mVpp; < 2 mArms
SPD1168X $ 259
SPD1305X $ 279
Info
https://int.siglent.com/products-overview/spd1000x/
https://www.siglentamerica.com/power-supplies/spd1000x-series-programmable-dc-power-supply/
Nice clean power ON
Datasheet:
https://www.siglentamerica.com/wp-content/uploads/dlm_uploads/2018/05/SPD1000X_DataSheet_DS0501X-E02B.pdf
Defpom videos:
« Last Edit: January 27, 2022, 09:54:57 am by tautech »
Offline maginnovision
Re: New SPD1168X Siglent PSU ?
« Reply #1 on: February 13, 2018, 10:24:10 pm »
Rebadge? I swear that looks familiar.
« Reply #2 on: February 13, 2018, 10:51:41 pm »
Maybe it's already being sold as a rebadge.
Siglent are the OEM for many brands....LeCroy, BK, RS........
« Reply #3 on: February 13, 2018, 11:14:54 pm »
I'm aware, that's the only reason I asked rather than assumed, haha.
Offline FordPrefect
  • Country: sk
« Reply #4 on: May 26, 2018, 10:42:51 pm »
Tonight I’ve checked siglent.eu and saw SPE1168X listed for about 2 hundred something Euro, IIRC. Went out for a few beers and when I came back to check it it disappeared. At least  there’s already user manual available at  https://www.batronix.com/files/Siglent/Labornetzteile/SPD1000X/SPD1168X-UserManual-EN.pdf
Offline KaneTW
« Reply #5 on: May 27, 2018, 12:58:57 am »
What are the known rebadged Siglent units?
« Reply #6 on: May 29, 2018, 05:31:49 am »
Info on these units now available on all Siglent websites.
OP edited.
Online nctnico
Re: SPD1168X Siglent PSU
« Reply #7 on: May 29, 2018, 12:07:55 pm »
Still 10mV/10mA accuracy so they might have left the extra digits out. Voltage: ±(0.03% of reading+10 mV) Current: ±(0. 3% of reading+10 mA)  :palm:
Offline BillB
« Reply #8 on: May 29, 2018, 01:30:28 pm »
The sense terminals are a nice feature.  Too bad they couldn't have squeezed these power supplies into a stackable form factor like the DMMs/AWGs.
« Reply #9 on: May 31, 2018, 10:45:26 am »
There's a few of the better known ones listed in this thread:
https://www.eevblog.com/forum/chat/remember-when-siglents-logo-wasnt-ugly/msg1577215/#msg1577215
Offline stenbror
  • Country: no
  • Software developer / Electrical Engineer
« Reply #10 on: June 07, 2018, 01:38:57 pm »
Dave..... Time for a teardown..........
Offline bugi
  • Hobbyist using the ultra slow and unsure method
« Reply #11 on: June 07, 2018, 04:20:57 pm »
Assuming they use "accuracy" and "resolution" somewhat correctly (although, as our lecturer used to say, it is never "accuracy" but "inaccuracy"), then the last digits still have their uses, e.g. to detect a small changes in them. Whether such was e.g. really from 1.234A to 1.235A or from 1.244A to 1.245A might in many cases be less important.  Of course, they have not specified how the inaccuracy behaves, but typically the shown values are still monotonic and linear enough.
(Otherwise most of the 7-8 digit multimeters could leave out 1-2 last digits, too, since most of them are "only" specified to be accurate to 6 digits, or 5 digits after a year.)
« Reply #12 on: July 18, 2018, 06:38:11 am »
Some quick facts/findings from the first I've seen of these:
2s boot time.
Quiet smart fan. 80mm. At no time with the following tests and loads did the fan speed increase.
2 sets of 650mm leads with croc clips, one set with open lug terminals and the other with molded banana plugs.
Output enable soft key driving an output relay. Note, the relay is only bought into ON switching function at voltages above 4.4V settings below which silicon is doing the switching.
19mm terminal spacing.
Overshoot test, high current.
12V set, 8A set.
12V halogen auto lamp, 5A draw.
DSO SDS1104X-E, 10x stock probe, Normal triggering.
Ripple check.
Load as above.
Overshoot test, low current.
4.4V set, 8A set
Red LED with 1k current limit resistor.
5mA displayed as drawn.
Ripple check.
Load as above.
More checks and tests later.
« Last Edit: July 19, 2018, 10:55:35 am by tautech »
The following users thanked this post: plurn, ssaenek
Online flash2b
« Reply #13 on: July 19, 2018, 08:28:14 am »
Is the spacing between de banana terminals the regular 19mm or still 20mm like the other Siglent units ?
« Reply #14 on: July 19, 2018, 09:25:19 am »
19mm.
Reply #12 updated to indicate this.
Offline janekivi
  • Country: ee
« Reply #15 on: July 19, 2018, 04:35:28 pm »
« Reply #16 on: July 20, 2018, 04:19:48 am »
And update reply #15 here to update power supply to 2.01.01.06R1
https://www.siglentamerica.com/service-and-support/firmware-software/dc-power-supplies/#spd1000x-series
Thanks.
2.01.01.06R1
505 KB
Changelog
1. Add key operation to accommodate knob functions
2. Button function instead of knob operation functions
« Reply #17 on: August 07, 2018, 08:05:56 pm »
Offline BillB
« Reply #18 on: August 11, 2018, 09:29:17 pm »
Has anyone tried to download and install EasyPower - 1.01.01.16 (Release Date 07.18.18 )?
When I get the the installer start-up screen, it looks like it might be the Chinese version.  The download from Siglent and Siglent America both do this.  I went through the installer anyway, and it seemed to install an English version!  However, upon execution and connection to a device, the app shrinks down to just its menu for a second then disappears.
I uninstalled it, and tried to go back to 1.01.01.13 and it now does the same thing.  The installation has also messed up EasyWave.  All sorts of unsupported operation dialogs appear during its execution, and then when connecting to a device it shows an invalid pointer dialog, then just displays the screen attached.  EasyDMM, EasyScope, and EasySpectrum seem unaffected.
I wanted to upgrade to the .16 version of EasyPower as .13 isn't compatible with the SPD1168X.  Another problem with .13 (or it might be with the SPDs themselves) is that static IPs don't work.  They can be assigned but EasyPower doesn't see them.
Completely uninstalling the EasyPower and EasyWave using the Windows Control Panel, and re-installing EasyWave and EasyPower .13 fixed it.  However, there is definitely something not right about that .16 version of EasyPower.
Windows 10 Pro v1803
« Last Edit: August 12, 2018, 01:14:26 am by BillB »
The following users thanked this post: tautech, TheDefpom
« Reply #19 on: August 11, 2018, 10:01:30 pm »
Yes, there's an issue with the EasyPower installer and I've asked Siglent to fix it.
Once past the installer it's all English UI.
Offline BillB
« Reply #20 on: August 11, 2018, 10:27:19 pm »
Thanks!  Check my post, as I updated it to include some other issues as well.
« Reply #21 on: August 11, 2018, 11:14:46 pm »
Thanks Bill.
For the record can we know which OS you're using ?
List it in your edited post if you like as that's what I'm linking to Siglent for their investigations.
« Reply #22 on: August 20, 2018, 08:39:23 pm »
Siglent notified me they've updated the EasyPower package and its installer UI. New version available:
https://www.siglentamerica.com/download/4323/
Offline BillB
« Reply #23 on: August 20, 2018, 11:01:43 pm »
Installed and tested.  Installer is in English and all functions work with the SPD1168X.
Has anyone else noticed the static IP issue?  All other equipment I have works fine using a static IP, but both the SPD3303X-E and this SPD1168X do not.
« Reply #24 on: August 20, 2018, 11:14:46 pm »
Thanks Bill, I'll shoot that through to Siglent.
Defpom is to have a look at the EasyPower SW soon so maybe he'll document this in a vid so Siglent can plainly see the issue.
