Author Topic: New Sigrok/PulseView hardware support (Siglent SDS HD, Rigol DHO...)  (Read 9601 times)
Offline teddychn
Hi Fredo,
Thanks for sharing! I'm really excited to try your patched version.
With just CH1 acquisition, it works perfectly with memory depth equal to or less than 4Mpts. However, PulseView seems to wait forever with a data length of 10Mpts. My environment is a Windows 10 PC with an SDS2000X HD. Please take a look at the attachments to see if they have any information useful to this situation.
Appreciate it!
« Last Edit: July 21, 2024, 08:45:37 am by teddychn »
Offline Electro Fan
Hi folks !
Back from a beautiful journey in Scotland, I patched the installer to try and fix the read timing issues 8)
Link has been updated on the first post, and you can find it here as well : Windows (64bits) installer (zip password is 'sigrok').
@Frex / @dpenev could you please try this new version and see if it works any better for your scopes ?
This new version should also support all Siglent recent series, that is :
  • SDS 800X HD Series
  • SDS 1000X HD Series
  • SDS 2000X HD Series
  • SDS 3000X HD Series
  • SDS 5000X Series
  • SDS 6000L Series
  • SDS 6000A Series
  • SDS 6000 Pro Series
  • SDS 7000A Series
Best,
Frederic.
It is very impressive and valuable what you and the other contributors are doing with this project!
Thanks!
The following users thanked this post: egonotto, fredo_
Offline fredo_Topic starter
Thanks for the feedback @teddychn !
I'm almost done with Rigol DHO800/900 support (thanks to the work previously done by Diana Ellefson (OrionOth) and RemiNV here).
I'll switch back to Siglent SDS2000X HD to try and reproduce your problem right after that.
The following users thanked this post: egonotto, thm_w, teddychn
~~~ Updated version with Rigol DHO 800/900 support ~~~
Hi folks !
Here is my attempt to add Rigol DHO 800/900 support to Sigrok/PulseView (link has been updated in first post too) : Windows (64bits) installer (zip password is 'sigrok').
Disclaimer :
- LA not tested since I only have a DHO 800 with an identity crisis  ;)
- Only works in TCP/IP mode
- Segmented mode only works if :
  1/ UltraAquire is manually activated on the scope (SCPI command to activate it does not seem to work)
  2/ Memory depth is set to 10Kpts or lower
Any feedback is welcome, especially from DHO 900 owners !
« Last Edit: July 22, 2024, 09:05:21 pm by fredo_ »
The following users thanked this post: egonotto, thm_w, ebourg, zelectronicauy
Offline Furna
  • I still don't know
I will try ASAP with my Siglent SDS824X HD and report here.
I was starting to work on this (see https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5546249/#msg5546249) but currently I am following too many projects; so a big thank you!
The sky above the port was the color of television, tuned to a dead channel.
The following users thanked this post: fredo_
Hi guys,
I just updated the patch with the following changes:
07/27/2024 Update
Siglent SDS :
- Fixed acquisition for memory depth > 4 Mpts
- Known limitations :
   - USB acquisition does not work (use TCP/IP with Raw TCP and port 5025)
   - LA acquisition might fail for memory depth > 50 Mpts
Rigol DHO :
- Fixed USB acquisition
@teddychn this should fix your issue with memory depth >4Mpts.
Please let me know if this is working for you guys !
Best,
Fredo.
« Last Edit: July 27, 2024, 05:02:49 pm by fredo_ »
Offline Spike
Hi guys,
07/27/2024 Update
Siglent SDS :
Rigol DHO :
Best,
Fredo.
Are you planning to keep the Siglent and Rigol support on separate branches from now on or will this get merged onto your master?
I will keep separated branches to be able to eventually create two distinct pull requests on Sigrok repository.
But I just merged the two branches on my master to make it easier for you to create a Mac OS build.
The USB fix is not included as I borrowed it from a PR on sigrok repository, but it's a Windows only fix, so no worries.
Offline Spike
Excellent!   Thank you very much.
Offline Spike
Did you push those back up?  I'm not seeing it.
Sorry, forgot to push, that should be good now!
Offline Spike
Got it now.  Thanks again.
Offline Spike
Hitting this while trying to compile the rigol stuff:
  CC       src/hardware/rigol-ds/api.lo
/Users/gcorral/Documents/Source/sigrok/libsigrok/src/hardware/rigol-ds/api.c:1038:4: error: expected expression
                        int frames = 0;
/Users/gcorral/Documents/Source/sigrok/libsigrok/src/hardware/rigol-ds/api.c:1040:55: error: use of undeclared identifier 'frames'
                        if (sr_scpi_get_int(sdi->conn, ":ACQ:ULTR:MAXF?", &frames) != SR_OK)
/Users/gcorral/Documents/Source/sigrok/libsigrok/src/hardware/rigol-ds/api.c:1042:8: error: use of undeclared identifier 'frames'
                        if (frames <= 0) {
/Users/gcorral/Documents/Source/sigrok/libsigrok/src/hardware/rigol-ds/api.c:1046:33: error: use of undeclared identifier 'frames'
                        devc->num_frames_segmented = frames;
4 errors generated.
Pretty sure this needs it's own scope or there needs to be a statement before that declaration.
                        int frames = 0;
                        if (frames <= 0) {
4 errors generated.
Yep, not sure why my compiler did not complain... I pushed the fix.
Offline Spike
                        int frames = 0;
                        if (frames <= 0) {
4 errors generated.
Looks good, thanks!
Offline teddychn
Hi Fredo,
Now it can download waveforms of more than 4Mpts. However, the waveform on PulseView seems off. I found that the issue starts at 5Mpts and occurs periodically. Please refer to the screenshots.
Thanks for your work and Best Regards,
Ted
Offline Furna
Hello Fredo,
I have the same behaviour seen by teddychn on my SDS824X HD; see screenshots.
2324169-0
2324173-1
First time I am using an oscilloscope and first time I am using Sigrock/PulseView ... still have to learn a lot.
Let me know if I can test anything specific and sorry for taking long to test and report.
« Last Edit: July 28, 2024, 08:18:58 pm by Furna »
Offline Frex
Hello,
I am back on vacation and then I tested your new Windows 10 installer.
(is it normal that the zip uses strictly the same file name "pulseview-0.5.0-git-d00efc6-installer"
 when they are different versions?).
Now, when the data points exceed 10 Mpts, only the first channel is acquired and then stops.
The other channels are not acquired and it is not possible to restart the acquisition.
I also noticed that a new icon appears in this case, indicating the sequence mode...
I don't know why. The resulting screenshot below.
I also noticed that the scope hang very often and need to be rebooted to work again.
Frex
Re: New Sigrok/PulseView hardware support (Siglent SDS HD, Rigol DHO800...)
« Reply #43 on: August 01, 2024, 06:52:28 pm »
Hi guys,
Well it's obviously not ideal but it's the easiest way for me to update the file without having to change the link on the different posts in this topic.
From now on, to make it easier to identify the version, I will add the date to the model description in the connection dialog :
Anyway, here is a new version (link has been updated in first post too) : Windows (64bits) installer (zip password is 'sigrok')
Changes in this version :
08/01/2024 Update
Siglent SDS :
- Fixed pagination for memory depth > 4 Mpts (issue where the waveform was truncated and replicated)
   - LA acquisition pagination (for memory depth > 5Mpts) is not working on SDS 2000X HD (firmware issue ?) causing the first 5Mpts to be replicated several times
This should fix the truncated waveform reported by @teddychn and @Furna.
@Frex, I reworked the acquisition logic in this version so could you please make another attempt with your SDS 2000X plus and send me the log window content with log level set to 5 ?
Regarding LA acquisition, I spent quite some time trying and understand how to have pagination work (data blocks are limited to 5Mpts, over that memory depth, data has to be paginated) but I came to the conclusion that the SDS2000X HD has a bug that prevents pagination to work. The result is that the first 5Mpts datablock is replicated several times on LA channels :-/
I ended up sending a mail to Siglent support to report the issue. Not sure if/when I'll get a response and this will be fixed...
Anyway, be aware that LA acquisition will not work properly for memory depth > 5Mpts.
Best,
Fredo.
Offline Furna
« Reply #44 on: August 01, 2024, 06:58:50 pm »
You might want to check
https://www.eevblog.com/forum/testgear/sds800x-hd-bug-reports-firmware/
https://www.eevblog.com/forum/testgear/siglent-sds2000x-hd-missing-features-and-bugs/
and contact forum member 2N3055 if you do not get an answer from Siglent.
« Last Edit: August 01, 2024, 07:25:49 pm by Furna »
Offline Spike
« Reply #45 on: August 01, 2024, 11:44:38 pm »
Hi guys,
(Attachment Link)
08/01/2024 Update
Siglent SDS :
Best,
Fredo.
Any chance this could be merged to master?
« Reply #46 on: August 02, 2024, 06:39:21 am »
Done !
@Spike if you have working Mac build, maybe you could share it here ?
« Last Edit: August 02, 2024, 07:05:20 am by fredo_ »
Offline Frex
« Reply #47 on: August 02, 2024, 08:25:31 am »
Hekko Fredo and all,
Renaming model name in dialog list is a good idea  ;)
That avoid confusing versions.
I tried your newer pulseview version, but it seem not working for me.
The "Run" button become green for about a second and then stop after clicking on it.
There is no resulting acquisition trace.
You can show below the log result (log level set to 5).
I add also a log file.
Thank you for all your efforts !
Regards.
FRex
« Reply #48 on: August 02, 2024, 09:41:43 am »
Thanks Frex for the feedback et log information !
Could you please try and put the scope in Stop mode before launching the capture ?
I suspect that the scope as not yet triggered when it receives de "DATA?" command...
« Last Edit: August 02, 2024, 11:08:25 am by fredo_ »
Offline Frex
« Reply #49 on: August 02, 2024, 02:14:03 pm »
I tried to put it in stop mode before to start acquisition, same behavior.
You can find the log result of few unsuccessful attempt below.
Regards.
Frex
