Hi guys,
(is it normal that the zip uses strictly the same file name "pulseview-0.5.0-git-d00efc6-installer"
when they are different versions?).
Well it's obviously not ideal but it's the easiest way for me to update the file without having to change the link on the different posts in this topic.
From now on, to make it easier to identify the version, I will add the date to the model description in the connection dialog :
Anyway, here is a new version (link has been updated in first post too) :
Windows (64bits) installer (zip password is 'sigrok')Changes in this version :
08/01/2024 UpdateSiglent SDS :
- Fixed pagination for memory depth > 4 Mpts (issue where the waveform was truncated and replicated)
- Known limitations :
- USB acquisition does not work (use TCP/IP with Raw TCP and port 5025)
- LA acquisition pagination (for memory depth > 5Mpts) is not working on SDS 2000X HD (firmware issue ?) causing the first 5Mpts to be replicated several times
- LA acquisition might fail for memory depth > 50 Mpts
This should fix the truncated waveform reported by @teddychn and @Furna.
@Frex, I reworked the acquisition logic in this version so could you please make another attempt with your SDS 2000X plus and send me the log window content
with log level set to 5 ?
Regarding LA acquisition, I spent quite some time trying and understand how to have pagination work (data blocks are limited to 5Mpts, over that memory depth, data has to be paginated) but I came to the conclusion that the SDS2000X HD has a bug that prevents pagination to work. The result is that the first 5Mpts datablock is replicated several times on LA channels :-/
I ended up sending a mail to Siglent support to report the issue. Not sure if/when I'll get a response and this will be fixed...
Anyway, be aware that LA acquisition will not work properly for memory depth > 5Mpts.
Best,
Fredo.
