Author Topic: New Sigrok/PulseView hardware support (Siglent SDS HD, Rigol DHO800...)  (Read 6154 times)
Offline dpenev
Thanks Furna,
I have  followed the procedure I have described two messages back and the log attached.
sr: scpi_tcp: Successfully sent SCPI command: ':TDIV? '.
sr: scpi: Got response: 'DAT2,#9000000000 AVEDESC1.00E+075.00E-04', length 40.
sr: session: bus: Received SR_DF_HEADER packet.
sr: scpi_tcp: Successfully sent SCPI command: 'WAV:MAXP? '.
sr: scpi: Got response: '5.00E-04', length 8.
sr: scpi: get_int: non-integer rational=500/1000000
sr: session: Could not start siglent-sds device tcp-raw/192.168.1.6/5025 acquisition.
'DAT2,#9000000000 AVEDESC1.00E+075.00E-04' looks a concatenation of few responses.
5.00E-04 is my current timing resolution 500us/div
WAV:MAXP?  if sent separately to the oscilloscope returns 10000000 but I don't see it in the log.
« Last Edit: Today at 01:31:29 pm by dpenev »
Online Furna
Thanks Furna,
Can you try with a different resolution? I was succesfull with 10mV/div with SDS824X HD
See also
https://www.eevblog.com/forum/testgear/new-sigrokpulseview-hardware-support-(siglent-sds-hd-rigol-dho800-)/msg5605601/#msg5605601
With SDS2104X+ it is not possible to go lower than 10mV/div and fredo_ is looking at it.
« Last Edit: Today at 04:12:57 pm by Furna »
The sky above the port was the color of television, tuned to a dead channel.
