Author Topic: New Siglent SPD4000X series power supply  (Read 27655 times)
Offline tautech
Re: New Siglent SPD4000X series power supply
« Reply #50 on: June 25, 2024, 04:12:35 pm »
Prices are up on the NA site although this page doesn't seem to show up from their front page yet.    https://siglentna.com/products/dc-power-supply/spd4000x-series/
SPD4323x is $680, SPD4121 is $780 and SPD4306X is $950.
Welcome to the forum.
Pricing is correct and official release is just a few days away.
Offline thm_w
  • Non-expert
« Reply #51 on: June 25, 2024, 09:58:41 pm »
SPD4121X would have been great but not sure I understand the choice of a 12V maximum output (12V 10A x2, 15V 1.5A x2).
Usually for automotive/battery simulation you'd want around 13 or 14V.
Even for testing a 12V product, you'd sometimes want to try +/-10%.
This is why ~6.3V is somewhat standard (for use with 5V designs).
« Last Edit: June 25, 2024, 10:00:23 pm by thm_w »
Offline exe
  • self-educated hobbyist
« Reply #52 on: June 26, 2024, 06:42:40 pm »
Ha-ha, I thought it's for vacuum tubes.
Offline KungFuJosh
  • TEAS is real.
« Reply #53 on: June 26, 2024, 07:26:07 pm »
I don't know why they chose those specific specs, but each of the 3 models appears to be geared towards different V/A requirements. The SPD4323X would be the only version I would consider, and that has nothing to do with it being the cheapest...which doesn't hurt either.
ETA: Okay, price did matter. I just looked again at the SPD4306X, and those specs would work too, but not for the price.
Offline KungFuJosh
  • TEAS is real.
« Reply #54 on: June 26, 2024, 08:45:32 pm »
Hmmm, this is interesting...
SPD4306X:
Weight   26.46 lbs
Dimensions   8.7 × 14.17 × 5.24 in
SPD4121X:
Weight   26.46 lbs
SPD4323X:
Weight   17.64 lbs
Dimensions   8.7 × 11.8 × 5.24 in
Seems like 2 of those might be the same hardware. I wonder what that might inspire. 🥸
Offline thm_w
  • Non-expert
« Reply #55 on: June 26, 2024, 10:23:59 pm »
For me if designing a lab PSU for use with valves (or 6V batteries) you'd probably choose ~8V.
You can look around at whats commonly available for lab PSUs: 60V, 50V, 30V, 27V, 15V, 6V, etc. Which makes sense for use on 48V, 24V, 12V, and 5V systems. 10-20% headroom.
12V - 10% gives you 10-11V, which no one uses as a standard voltage.
SPD4306X: Weight   26.46 lbs - 15V 1.5A, 1A, 30V 6A x2
SPD4121X: Weight   26.46 lbs - 15V 1.5A x2, 12V 10A x2
SPD4323X: Weight   17.64 lbs - 6V 3.2A x2, 32V 3.2A x2
I added the voltage specs above. Its a completely different transformer winding I would think.
Offline KungFuJosh
  • TEAS is real.
« Reply #56 on: June 26, 2024, 11:28:44 pm »
That's certainly one possibility, but it's not the only possibility. Let's speculate! 😉
Offline tautech
The following users thanked this post: egonotto, thm_w, Mortymore, KungFuJosh, symphonystars, Furna, mon, atroz
Offline hpw
« Reply #58 on: July 16, 2024, 07:23:39 am »
Is there any SPS4000X_Service_manual seen/given yet? As the SPS5000X_Service_manual even exists already.
While the Ch1/Ch4 meter alters IMHO a bit to much as cold to warm up .. and how user calibration values alters the meters.
Hp
Offline tautech
« Reply #59 on: July 16, 2024, 07:33:43 am »
Not yet.
It's been released for 3 years.
https://www.eevblog.com/forum/testgear/siglent-sps5000x-psus-coming/
Which product ?
Offline Kawakneurder
« Reply #60 on: July 16, 2024, 09:33:57 am »
Looks like quite an interesting supply, the 4323X and 4306X especially.
Noise and load regulation are exceptional for the high current output (compared to similarly priced PSUs).
I am wondering about transient behavior (ex. time to switch from CV to CC mode, and residual energy in the output if it suddenly switches to CC mode).
@Tautech Do you have any idea how large the output capacitance is? Or do we have to wait for a teardown from Dave ;)
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #61 on: July 16, 2024, 10:35:36 am »
hm, keypad and 1 rotary encoder... So you want to adjust the output voltage on CH1. You turn the encoder and ooops, magic smoke. You just adjusted CH2.
Many lab power supplies have the ability to set overvoltage and overcurrent thresholds on a per channel basis - if you try to exceed the limit, the channel is disabled.  This has kept me from blowing up all kinds of things over the years :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline pdenisowski
« Reply #62 on: July 16, 2024, 10:38:09 am »
Perhaps you are right but maybe if the people would carelessly use leads with bare metal showing in HV situations it may be advantageous in the long run to allow them to win their award.  >:D
Does this count? It's only 40 amps at 20 volts ... :)
(Please don't try this at home)
« Last Edit: July 16, 2024, 10:39:53 am by pdenisowski »
The following users thanked this post: egonotto, exe, jjoonathan
Offline jjoonathan
« Reply #63 on: July 16, 2024, 01:41:31 pm »
HC is a lot of fun, you get to throw sparks, melt things, and it isn't trying to jump through the air to kill you. Just don't forget your safety rag and fire extinguisher!
https://youtu.be/uXEPy6Za6cI?t=218
(Since it has been a decade since photonicinduction's heyday, I should probably explain the bit: the fire extinguisher was a spray bottle with water for the many times he caught the carpet on fire.)
The following users thanked this post: egonotto, pdenisowski
Offline hpw
« Reply #64 on: July 16, 2024, 03:12:43 pm »
To change from any modes, the related output's have to be switched OFF & On again .... the given cable is rated as 3A with twisting "bunch plug". Those twisting "Bunch Plug" are a culprit of no contacts/loosing contacts.
In the custom calibration mode as for first use, all channel 's values V & I, needs to be carefully set !! Otherwise  |O
« Last Edit: July 16, 2024, 05:15:56 pm by hpw »
Offline mon
« Reply #65 on: July 17, 2024, 07:15:31 am »
AppVision now has listings up for AUD pricing:
SPD4323X $1,122.00
SPD4121X $1,287.00
SPD4306X $1,595.00
Pretty comparable to the US pricing.
Now I need to calm my itchy trigger finger and wait for Dave to take one apart... Would hate there to be a repeat of the SPD3000x's early unit issues.
Offline hpw
« Reply #66 on: July 17, 2024, 08:33:25 am »
To note:
- if you power C2 or C3 as 10V and switch on without any load, the current setting should have any value > 0.000A, otherwise no output voltage seen... setting like 0.010A shows than 10V at the meters otherwise nada.
- nice would be a simple factory copy to the user calibration table, so simple to calibrate and reset user calibration to valid state.
IMHO, to test the gear really, any dynamic test (comprehensive test) would be required using a good electronic load gear.
Offline tautech
« Reply #67 on: July 17, 2024, 09:31:32 am »
To note:
Normal.
As this can bluff some ppl we always dispatch with 1V 1A settings on all channels.
Offline slavoy
« Reply #68 on: July 17, 2024, 09:59:05 am »
No info about the measurements refresh rate in the sheets   :o
The following users thanked this post: pdenisowski
Offline tautech
« Reply #69 on: July 17, 2024, 10:04:33 am »
List time accuracy < 50 ms might be related.  :-//
Offline pdenisowski
« Reply #70 on: July 17, 2024, 10:48:53 am »
Yes, almost all "proper" power supply testing should be done using a high-quality electronic load.
Online 2N3055
  • Country: hr
« Reply #71 on: July 17, 2024, 11:06:46 am »
Could you point me to any modern PSU by likes of Keysight and R&S that specifies that parameter?
I checked 5-6 of them and not a mention...
Offline pdenisowski
« Reply #72 on: July 17, 2024, 12:32:17 pm »
Could I ask what you mean by "measurement refresh rate"?  If it's how fast readback data can be logged, that definitely is in our spec sheet. We also specify the sampling time used for statistical measurements.
https://scdn.rohde-schwarz.com/ur/pws/dl_downloads/dl_common_library/dl_brochures_and_datasheets/pdf_1/NGU_dat_en_3608-6802-32_v0201.pdf
I also did an entire "technology" video explaining power supply readback and logging
and one specifically on how this is done on our NGM power supply (normal and "fast" logging)
« Last Edit: July 17, 2024, 12:34:24 pm by pdenisowski »
Online 2N3055
  • Country: hr
« Reply #73 on: July 17, 2024, 01:38:29 pm »
With do all respect, NGU is NOT a standard lab PSU, but an fancy/expensive SMU.
It is a source/measure unit and measuring is part of primary function of the instrument.
I checked for several Keysight and R&S standard PSU units and there is not even a single mention of how fast internal V/A meters sample values..
Or how fast is request, measure, reply cycle time for SCPI readout, on various interfaces.
Offline pdenisowski
« Reply #74 on: July 17, 2024, 03:01:30 pm »
Point well taken - I just happened to have the NGU datasheet open because I was answering a question about it in another thread.  That was careless of me and I apologize for not choosing a comparable supply :)
I'm assuming "measurement refresh rate" refers to how fast readback data values can be logged -- there is a human-perception limit with regards to how fast they can be viewed on a power supply display.  If this definition is correct (and it may not be), then "measurement refresh rate" would have to refer to supplies that can log readback values -- I'm not sure that a "readback display update rate" value would be helpful or relevant.
It appears that the new Siglent power supply does not support logging, so I'm not surprised that no value for "measurement refresh rate" was given.  (And that's not a slam on Siglent - our comparable HMP4000 series supply also does not support logging).
Many R&S basic / entry level power supplies do however support logging, and when they do, this is specified.  It's not just the "fancy/expensive" ones :)
https://www.rohde-schwarz.com/us/products/test-and-measurement/dc-power-supplies/rs-ngc100-power-supply-series_334248.html
Again, my apologies for not using a better example in my original post.  Thanks for keeping me honest!
