Author Topic: New Siglent SPD4000X series power supply  (Read 21979 times)
Offline oeweanTopic starter
  • Country: no
    • Adroit.no
« on: September 18, 2023, 01:00:23 pm »
Siglent has a new power supply, SPD4000X series.
Looks nice and well speced.
https://www.siglent.com/products-overview/spd4000x/
Norwegian distributor of test and measurement equipment....
Adroit.no
The following users thanked this post: tautech, 2N3055, LuisBe, delvo
Offline blurpy
  • Country: no
Re: New Siglent SPD4000X series power supply
« Reply #1 on: December 11, 2023, 01:40:19 pm »
Video here:
Looks like only 2 of the channels are 32 volts.
Offline mawyatt
« Reply #2 on: December 11, 2023, 02:37:21 pm »
Looks like they got the banana terminals finally spaced properly  ::)
Seem relatively expensive compared to the SPD3303X-E, altho having 4 channels like the GPP-4323 is nice, as is remote sense on 2 channels :-+
Best,
~Wyatt Labs by Mike~
Offline nctnico
« Reply #3 on: December 11, 2023, 03:28:16 pm »
And it has a numeric keypad.
The following users thanked this post: rf-loop
Offline Antonio90
« Reply #4 on: December 11, 2023, 03:35:52 pm »
Is it made by GWInstek?
Offline 2N3055
  • Country: hr
« Reply #5 on: December 11, 2023, 03:38:59 pm »
What kind of question is that?
They are both manufacturers.
Others rebrand their products, respectively....
Offline nctnico
« Reply #6 on: December 11, 2023, 04:13:41 pm »
A very logical one as Siglent and GW Instek have sold the same power supply before.
On second look I notice the USB-A is at the back instead of on the front. Who thought of that?
« Last Edit: December 11, 2023, 04:19:52 pm by nctnico »
Offline 2N3055
  • Country: hr
« Reply #7 on: December 11, 2023, 04:42:09 pm »
Seriously ?
I had no idea that was the case...
Which one?
As far as I know that is not so now...
Offline Antonio90
« Reply #8 on: December 11, 2023, 05:46:53 pm »
Just curious, my apologies if it's a stupid question. It struck me as quite similar to the GPP range, visually speaking and in terms of layout. Not saying they are identical, but I wouldn't be surprised if they share the front-panel PCB, or use a very similar one.
Also, if I'm not mistaken, The SPD3303X-E shares at least the output stages with a GWInstek PSU, can't remember which.
I don't say that as a bad thing, I quite like GWInstek.
Offline tautech
« Reply #9 on: December 11, 2023, 08:08:30 pm »
FYI
SPD1000X models use 19mm terminal spacings.
I too ask for qualification for this statement.
To date, none of the Siglent linear PSU's had a USB A port at all and this is a welcome addition to the range so to not need PC SW to update firmware and use USB external memory to store/load setup/config files.
Out of office and unavailable for a few days.
Offline 2N3055
  • Country: hr
« Reply #10 on: December 11, 2023, 08:11:04 pm »
No not stupid, I was just confused because AFAIK they don't do rebrands, other rebrand their products.. I'm not aware of any collaboration with GW Instek in that regard.
And yes,I like GW Instek too, very decent company and products.
Offline nctnico
« Reply #11 on: December 11, 2023, 09:33:04 pm »
The GW Instek GPD-3303S shares the same construction and the same output stage. And it wouldn't surprise me if this collaboration goes much further than this product. After all, GW Instek has a much longer history designing power products compared to Siglent. It wouldn't make sense re-invent the wheel just to satisfy NIH syndrom.
« Last Edit: December 11, 2023, 09:45:40 pm by nctnico »
Offline tautech
« Reply #12 on: December 11, 2023, 09:50:59 pm »
And 6A each.
SPD4306X looks the most interesting/capable model with two 30V 6A and two 15V 1.5A outputs which if can be seriesed/paralleled provides for a useful range of outputs.....
60V 6A or 30V 12A would be very handy for some.
Online Martin72
  • Testfield Technician
« Reply #13 on: December 11, 2023, 10:05:22 pm »
Quote from: oewean
Looks nice
Not for me, although I generally have a problem with the look of today's power supply units, which are becoming more and more overloaded and pop-colored.
The second point, which is not so interesting for private use, is the terminals.
At work, we only use 4 mm safety test leads, which don't fit in there.
No, for once I'm not impressed by a siglent product, I like the 4-channel from GW Instek much better, both visually and in terms of the connections.
(Kierkegaard)
The following users thanked this post: Markus2801A
Offline tautech
« Reply #14 on: December 11, 2023, 10:26:42 pm »
Shrouded retractable ones ?  :-//
Offline Antonio90
« Reply #15 on: December 11, 2023, 10:39:45 pm »
The Instek is quite nice, although 33% more expensive than the equivalent Siglent (chinese MSRP)
Will any of the Siglent offerings operate on two quadrants as the GPP?
I have a GPD-4303S, which I like quite a bit except for the fact that it can only turn on and off all channels at once. I did burn a cheap 3v chinese scale with 20v by mistake thanks to that. Also, no numpad. This looks like a very good replacement.
Online Martin72
« Reply #16 on: December 11, 2023, 10:50:24 pm »
We have a few dozen of them as a temporary solution for our old devices without safety bananas(until they will be replaced).
I'm certainly not going to buy appx 300 new cables so that I can use a power supply unit with such terminals
In addition, these sliding sleeve cables are mechanically fragile and of poor quality, even though they come from Hirschmann.
(Kierkegaard)
Offline tautech
« Reply #17 on: December 11, 2023, 11:12:02 pm »
Hmmm, never had such problems with the 100's we've supplied from Aliexpress.  :-//
However we did get a sample shipment for assessment before bulk purchase.
Online Martin72
« Reply #18 on: December 11, 2023, 11:19:51 pm »
We use them daily under partly rough conditions, not only to connect something that is on a lab table. ;)
(Kierkegaard)
Offline temperance
« Reply #19 on: December 11, 2023, 11:58:12 pm »
hm, keypad and 1 rotary encoder... So you want to adjust the output voltage on CH1. You turn the encoder and ooops, magic smoke. You just adjusted CH2.
I don't like those power supplies for generic daily use and prefer supplies with separate pot's or encoders for current and voltage for each channel.
Offline nctnico
« Reply #20 on: December 12, 2023, 12:26:43 am »
Typically I never use the encoder on a PSU with a keypad. Typing in the number is quicker and you can cancel before comitting the new setting.
Offline tautech
« Reply #21 on: December 12, 2023, 06:12:45 am »
Dwelling on these comments, I believe many instead will prefer terminals that provide connection options.
Generally the hobbyist prefers multiple connection choices and I certainly do as when I built my first PSU one of the must haves was cross hole drilled binding posts with banana sockets which is just what this new Siglent PSU provides.
This allows for plain wire, fork and banana connections.
OTOH your work you may have different requirements for outputs than the target market Siglent has catered for.
Offline 2N3055
  • Country: hr
« Reply #22 on: December 12, 2023, 07:07:55 am »
I don't understand why more manufacturers don't use these...
The following users thanked this post: rf-loop, nctnico, exe, Mortymore, colorado.rob, temperance, Martin72, NE666
Offline NE666
« Reply #23 on: December 13, 2023, 01:23:00 pm »
Yup, and note the sense terminals on the front panel too  :-+
The following users thanked this post: _Wim_, 2N3055, Mortymore
Offline 2N3055
  • Country: hr
« Reply #24 on: December 13, 2023, 01:25:32 pm »
Yep..
