Why isn't that a normal mode of operation?
I should've word it better, what I meant is that direct into CC is not exactly commonly used feature. And the problem mentioned above is not "normally" appliable to the use case presented in the posted question.
Yes I agree that proper CV
AND CC is expected (and should be guaranteed) mode of operation, but CV is by far the more common usage and is the one that applies to the posted question, and so far no decent PSU fails so bad that it violate CV setpoint.
To put it simply, the particular problem discussed here is
not where you set your PSU at 3.3V and it somehow overshoot to 8.0V. It is where you set 10mA and it somehow go all the way to 160mA.
