I agree tautech, I prefer to think after the event.
Navigating through the captured data on this scope isn't intuitive though, it seems the scope is always fighting you.
You're just used to doing it a different way.
Some hangover from CRO days maybe ?
What can help is to take note of the memory depth on the top right of the display for the timebase you are using.
When you need the detail sloooooow her down, then do the capture and then investigate what you've got. Use the power of a DSO, grab large captures then zoom in on the detail with either the timebase or Zoom.
Remember to use the push functions of the position controls that all zero positions and the Trigger level one that sets it to 50%.
Spend a little time just doing simple stuff to gain familiarity with this scope......it's all there, you just need to get your head around it.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
BTW how's the Decode usage going ?
Get it doing the business them back the timebase out and then use Zoom and horizontal pan to look through the string.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
