A new and very welcome feature that I've not seen before in Siglent scopes.
User definable Default setup.How many times have you turned on your DSO to do something quite different from the last time you used it ?
Often I bet.
How long does it take to return channels, trigger settings, delay, input attenuation etc. to some setting you know is an approximate good starting point or do you just punch the Default setup button ?
Oh wait, now the timebase has been set to some setting way off from where you need it and the channel attenuation has be set to the default 1x.
We all use our probes on 10:1, right ?
Well the X-E has come to our rescue with a simple interface to save ALL OUR favourite Default settings, yep, whatever you like.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Tune your X-E to your favourite settings and follow the syntax below.
Save/Recall button, select
Save Type:
To Default Key and then toggle the next key to
Current Setup and then press Save.
Don't like it, toggle from Current Setup back to Factory Default.
Easy.
![](https://www.eevblog.com/forum/testgear/new-siglent-sds1000x-e-oscilloscope-based-on-xilinx-zynq-7000-soc-architecture/?action=dlattach;attach=311425)
Edit.
Just to say this feature does not change any settings at power on boot, it is only to customise Default setup if the user requires their own custom Default settings.
