Author Topic: New Siglent SDS1202X-E oscilloscope based on Xilinx Zynq-7000 SoC architecture  (Read 143197 times)
Offline tautech
Here data sheet pdf until downloadable from Siglent web side.
There is an error near the end, Optional Accessories should start at where the last Standard accessory CD is listed.
Offline simone.pignatti
We also noticed that, but when looking better there is a very thin line which divides standard form optionals
Technical Support
Offline MrW0lf
  • Country: ee
    • lab!fyi
True Measurement to 14 Mpoints
At any one timebase, the SDS1000X-E can measure using all 14M sample points. This ensures the accuracy of measurements while the math co-processor decreases measurement time and increases ease-of-use
:-+ Poor mans Tek?
Offline rf-loop
Yes it need bit clarify.
Offline ebastler
Not sure whether this has been discussed before: How does the scope handle SPI decoding (SCL, MISO, MOSI, CS) with just two inputs?
i would assume scl + miso (or mosi) + timeout
unless in the meantime they added the third digital channel
That might work, but they explicitly list all four signals, including chip select. If you want to use that in the decoding, it seems that you can't get away with just two channels.
And the manual (page 86 ff.) bluntly explains how to set up all four signals, one after the other. Does this section refer to a different scope?
Setup for SPI Signals
Setting the SPI (Serial Peripheral Interface) signal includes two steps: connecting the
CLK, MISO, MOSI and CS signals to oscilloscope; specifying the parameters of each
input signal.
Offline rf-loop
Thanks. Not sure whether this has been discussed before: How does the scope handle SPI decoding (SCL, MISO, MOSI, CS) with just two inputs?
It can not do all simultaneously.
It can: SCL,  MISO  or   SCL, MOSI
CS Type: SCL (CLK) time out.
SPI function is limited due to only 2 signal.
It looks like User manual need more accurate personalize for SDS1000X and SDS1000X-E models for SPI but also some other things.
Only SDS1000X+ can use all  together: CLK, CS,  MOSI, MISO
« Last Edit: April 07, 2017, 08:27:28 am by rf-loop »
Offline JPortici
isn't the manual also the same for sds2000x?
Offline GeorgeOfTheJungle
  • Country: tr
I don't see no area measurements (mVs / Vs) ? Even the 1000z has that. You use that to derive mAs/mAh from a current sense signal.
« Last Edit: April 07, 2017, 10:06:51 am by GeorgeOfTheJungle »
  • Country: tr
There are other things I don't see nowhere in the pdfs:
-What's the max mem depth when the decoder in on? (it was 1.4MB (not 14!) in the 1000X)
-Can it decode up to 100ms/div sweep rate or just at 20ms/div max as the 1000X?
Offline rf-loop
Up to 14 M points trigger and decode. (It reads in product introduction ppt)
At the moment, until further notice, max is 20ms/div.
Offline JPortici
that's nice.
Offline tautech
Comparison table against GW attached.
(not prepared by tautech)
Offline pascal_swedenTopic starter
  • Country: no
It will be interesting to see if the hardware architecture can be reverse engineered, and if it is possible to do your own software projects on this scope.
Forum user "wingel" is from Sweden and did this for the Owon SDS7102 oscilloscope:
http://hackaday.com/2016/06/29/reverse-engineering-the-owon-sds7102-oscilloscope/
Offline Fungus
I wonder if it comes with the C++ compiler on board.  :popcorn:
(and VIM.  :-DD )
Offline Rolo
Got a mail today from siglent.eu that the SDS1202 is avaliable for pre-order. Just for info, have no relation with seller.
Price is ex VAT (BTW in The Netherlands)
  • Country: no
That photo is incorrect.
The screen is too big. It shows the LA slot, and a blue print button. The USB is not on the right of the selection buttons.
Offline rf-loop
Really weird they use totally wrong image. :rant:  Siglent  head office have shared right images to distributors.
Selling with wrong image is least fraudulent
Here official images (resized/cropped to small size by me)
« Last Edit: April 09, 2017, 05:10:21 pm by rf-loop »
  • Country: no
Why do the feet on the back of the oscilloscope have a curved slope? Is that also with the other Siglent oscilloscopes? First time that I see this, actually :)
Offline ebastler
No worries, that's the new Silgent scope in the picture, not the Siglent...  ;)
Welcome to the land of pluses and pulses, Siglent!
Offline tautech
FYI
http://www.siglent.eu/ IS NOT http://www.siglenteu.com/index.aspx
They are a distributor not the Hamburg branch of Siglent.
Offline StillTrying
  • Country: Broken Britain
So that the back feet stay in contact with the surface when extending the front feet as in the 3rd photo ?
They look near enough identical to the CML+, but at least on the CML+ what looks like soft rubber to stop it sliding back when you press a button is actually just textured plastic - so it does slide back!
  • Country: no
We should get this oscilloscope for Christer Weinigel! :)
Offline thanasisk
Available for preorder for 359E +vat
But no details on actual or approx shipping date!
http://www.siglent.eu/sds1202x-e.html
« Last Edit: April 10, 2017, 08:39:17 am by thanasisk »
Offline EEVblog
Threads merged.
Offline ProBang2
Because this feets and the two support posts (at the upper corners of the backside) are there, it is possible to lay the oscilloscope flat on the back.
Would be making much more sense with a mobile (battery driven) unit...   :-//
