Author Topic: Looking for a good handheld multimeter, Metrix MTX 3292?  (Read 2259 times)
Offline MagnumTopic starter
« on: November 24, 2018, 05:30:25 pm »
Hello,
I am looking for a good handheld multimeter for use in the field. Application is mostly aviation (up to 30V) and automation engineering with current, voltage and temperature (PT100/1000/Type K) measurements.
Right now I use a Keysight U1273A, quality is good, specs ok for me and I even like the display. It does the job, but I think there are meters out there which can do a bit more.
What I am looking for:
- Specs at least as U1273A
- Overall size as small as possible, U1273 is ok
- Quick startup
- Math function
- Big display with secondary measurement (e.g. math function)
- Very quick peak detect
- Very quick continuity tester
- Fast Autorange
- Good built quality
- Should be known to calibration labs, with standard or well documented calibration procedures.
Until now I found the Fluke 289 and the Metrix MTX 3292/3293.
The Fluke is well known, good quality, very good specs. Price is ok, but it is big and heavy. And it takes a long time to startup.
Then I stumbled over the Metrix 3292/3293. Price is a bit higher than the Fluke, but it is really small (even smaller than the U1273A).
Specs are are appox. the same as U1273A and has all the wanted features. Even a spec mode, where it displays its accuracy depending on the measured values. Really great, saves me the time to recalculate everything.
I have not found much about this meter on the internet, maybe someone is using it here?
Are there any other good alternatives out there which meet my demands? Or is the MTX 3292 already on of the best?
Thanks,
Magnus
Offline coromonadalix
Re: Looking for a good handheld multimeter, Metrix MTX 3292?
« Reply #1 on: November 24, 2018, 06:04:52 pm »
Try to find how much they cost to calibrate if needed in the future, your choice may change ???
In some case maybe they will give a link to download a calibration software ??
They did on my Metrix mx556 ?
For me an oled display is a no go vs an color 320x240 lcd
Metrix is a 100,000 count display  vs a 30,000 count,  the Metrix has better dc accuracy, the metrix has a bluetooth option model, optical usb port like the keysight.
Metrix         https://www.aemc.com/userfiles/files/resources/datasheets/Digital-Multimeter/2154-03.pdf
Keysight     http://literature.cdn.keysight.com/litweb/pdf/5990-6425EN.pdf
metrix 3292 video in french:   https://www.youtube.com/watch?time_continue=1&v=IgOVzitEcuI
you have to compare them on a sheet  loll
keysight 0,05% dc accuracy   mtx 3292 is 0.03,  mtx 3293 is 0.02
Keysight is ok to open the battery door and remove blown fuses,  dont know for the Metrix ?
Metrix, you have an ac adaptor  like the Gossen Meters, the Metrix can run while charging.
keysight  10,000 measurment points,  3292 is 1000, 3293 is 6500
Battery life seems identicals : 100 hrs each
and the list goes on ...
« Last Edit: November 24, 2018, 06:07:49 pm by coromonadalix »
« Reply #2 on: November 24, 2018, 06:44:40 pm »
Thanks for the reply.
I don't want to compare the MTX3292 with the U1273A, as I already have the Keysight. I am looking for a meter that is better than the Keysight, and the Metrix seems to be.
I am just checking if there is another alternative to the MTX3292 (as the Fluke 289, but for me the Metrix seems to be better).
« Reply #3 on: November 25, 2018, 03:26:13 am »
and the keysight U1282A series ???
    IP67 certified water-and-dust resistance withstands harsh environments and drops up to 10 feet
    60,000 counts resolution and 0.025% basic DCV accuracy
    Continuity tests with visual and audio alerts
    Built-in Low Pass Filter for accurate VFD troubleshooting
    Vsense alerts in the presence of high AC voltage
    Stay productive with 800 hours of battery life and datalogging via Bluetooth
    Built-in square-wave generator
    CAT III 1000 V and CAT IV 600 V Overvoltage Protection
    Max. Reading Speed    40 readings/s
    Internal Memory    10,000
    Connectivity    IR to USB or Bluetooth
