Today, better a few minutes ago, I check the bodeplot and XY demo.
For the bode plot the demo board got a lowpass and bandpass filter, I didn´t check if its an active one or passive.
Connecting is simply: Output of the generator (in this case the built-in of my HD scope) into the filterinput via bnc, then one probe to the testpoint "In", the other to "BP" or "LP", thats it..
I´ll follow the suggestion of the manual and adjusted the range between 200hz and 10Mhz.
Then checking XY - something I never used before
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Therefore I was a little bit surprised, how less you can do/adjust in this mode.
Also that I must change the connection of the scope, before it was Ch1 and Ch4, but that won´t work, it must be Ch1 and Ch2.
Known stuff for other, but new to me..
Nevertheless, the setup is simple and worked immediately.
Pics showing the demoboard´s BP at 5khz and 1khz (you can play along with the frequencies on board).
The displaying of the XY and the channels simultaneously like in the screenshot of the manual seems not possible on the siglent.
Martin
