Hello IRB,
Thank you for your feedback.
As I understand, you don't use an Ethernet link but the USB. Right ?
On my side, on the web control page in browser I'm able to use "print screen" button
of the web interface.
Anyway, I'm not able to take control of analyzer by clicking on screen in web browser.
There is always a message on bottom of screen "RESPONSE:NULL".
Are you able to control the RSA with your mouse in the web browser ?
Regards.
Frex
Normal I only use the USB. To try to help I connected the Ethernet, too.
I set up the TCP with a fixed IP to do the testing I noted in the message above, sorry if I wasn't clear.
Yes, I used the web browser called Chrome, and the mouse not the keyboard.
My unit did not go in to RMT until I communicated over the USB.
I was able to send the save screen to the USB drive, I thought that was what you were asking for help with...
When using the web browser, my program can not get the screen image, the port is in use by the browser. And vice versa, one has to release the port for the other to run. I was successful at using my program to get the screen image, I ran my program and connected to the Rigol then I opened the browser, and both are working together.
OK, in the browser I clicked the gears at the to edge of the screen, there you can lock the Keypad and the Touch Screen.
HOWEVER, when I locked the touch screen the browser mouse functions had no affect on the analyzer.
Also with the keypad locked and the touch screen locked, I had to use the keypad to unlock the keypad first then to unlock the touch screen.
I hope this helps.
I did notice the the "CONNECTED" switches to "NULL" after I click on an option then after it completes the command it returns to "CONNECTED"
