Author Topic: New Rigol DS2000-S series with built-in dual-channel 25-MHz AWG  (Read 37239 times)
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
We discovered this over in the Rigol DS2000 review thread - but I thought it warranted a new thread. New S versions of the DS2000 series are coming out, with built-in dual-channel 25-MHz AWG
DS2000-(S)ource
Here are translated specs from this document:
Number of Channels 2
Sampling rate 200MSa / s
Vertical resolution of 14bits
Maximum frequency of 25MHz
Standard waveforms sine, square wave, pulse, triangle wave, noise, DC
Arbitrary Waveform Sinc, the index rose, the index fell, ECG, Gauss, haversine
The sinusoidal frequency range from 0.1Hz to 25MHz
Flatness of ± 0.5dB (relative 1kHz)
Harmonic distortion of-40dBc
Spurious (non-harmonic)-40dBc
1% total harmonic distortion
Signal-to-noise ratio 40dB (TBD)
Square / pulse frequency range of 0.1Hz to 15MHz
Rise and fall time <15ns
Overshoot <5%
Duty cycle of 10-90%
Duty cycle resolution of 1% or 10ns (whichever is the greater value)
The minimum pulse width of 20ns
Pulse width resolution of 10ns or 5 (whichever is the larger value)
Jitter 500ps
Triangle wave frequency range of 0.1Hz to 100kHz
Linearity 1%
Symmetry 0-100%
Noise bandwidth of 25MHz (typ)
Arbitrary wave frequency range of 0.1Hz to 10MHz
Waveform length 2 ~ 16k points
Internal storage of 4
Frequency accuracy of 100ppm (less than 10kHz) 50ppm (greater than 10kHz)
Resolution of 0.1Hz or 4, whichever is greater
The amplitude output range 20mVpp ~ 5Vpp, high impedance 10mVpp ~ 2.5Vpp, 50ohm
The resolution 100uV or 3, whichever is the greater value
Accuracy of 2% (1kHz)
DC offset range ± 2.5V, high impedance ± 1.25V, 50ohm
« Last Edit: April 16, 2013, 09:51:42 pm by marmad »
  • Country: aq
    • DaysAlive
Re: New Rigol DS2000-S series with built-in dual-channel 25-MHz AWG
« Reply #1 on: April 16, 2013, 09:54:07 pm »
The latest DS2000 firmware includes support for the S series:
Version: 00.01.00.00.03   Date: 2013-4-1
E: Enhancements / M: Modification
1.      Added SCPI command for decoding data   E
2.      Fixed the cursor window error when change cursor mode(201303000020)   M
3.      Added option for power analysis (PC software)   E
4.      Fixed screen saver error when the scope have a trial license   M
5.      Fixed Anti-Aliasing error when reboot the unit   M
6.      Optimized the sampling rate in AC or Ext trigger   E
7.      Fixed “open record” error    M
8.      Optimized the trace display in normal trigger mode when change the horizontal or vertical setting   E
9.      Optimized the speed of PNG file storage   E
10.      Fixed the data error of .csv file   M
11.      Increased the sampling rate in ROLL mode   E
12.      Switched the position of channel in XY mode   M
13.      Optimized the compatibility for updated flash chip and writing/reading speed   E
14.      Changed the RUNT as standard trigger    M
15.      Support DS2000-S series   E
Offline nack
« Reply #2 on: April 16, 2013, 10:27:03 pm »
Any thoughts on what physical (dual) output they will use? Two new dedicated BNC connectors on the front/rear panel?
Offline thm_w
  • Non-expert
Offline Hydrawerk
« Reply #4 on: April 16, 2013, 11:22:48 pm »
Looks great. I hope there will be no bugs.
  • Country: aq
    • DaysAlive
« Reply #5 on: April 16, 2013, 11:25:53 pm »
The photo shows two new BNC connectors on the rear:
  • Country: aq
    • DaysAlive
Offline EEVblog
« Reply #7 on: April 16, 2013, 11:29:16 pm »
Very inconvenient!
But not a show stopper.
Agilent started an awesome trend here.
Offline EEVblog
« Reply #8 on: April 16, 2013, 11:31:36 pm »
It's got full ARB capability, but will that be usable? i.e. using a waveform capture or download?
They are most likely sharing technology from their DG2000/4000 function gens.
They won't want to step on the toes of those products too much though.
  • Country: aq
    • DaysAlive
« Reply #9 on: April 16, 2013, 11:36:14 pm »
I'm curious how it will work. The docs mention internal storage capability of 4 waveforms.
  • Country: aq
    • DaysAlive
« Reply #10 on: April 16, 2013, 11:37:48 pm »
Very inconvenient!
Yes, I hate back BNC connectors... but I guess they're saving that knockout in the front for an MSO module some day.
Offline ivan747
« Reply #11 on: April 16, 2013, 11:53:47 pm »
Rigol is really raising the bar. Now they just need people's confidence to compete with the bigger manufacturers. Some people around here still hate their support depertment. I fear for Tektronix's long-term future. (Will they be here in 20 years?)
Offline EEVblog
« Reply #12 on: April 17, 2013, 12:00:27 am »
Unfortunately, Tek are almost insignificant in the low and mid range scope market now, and this just pushes them further down the ladder.
And rumour has it they have nothing on the cards to compete with.
I hope that's not the case.  :(
  • Country: aq
    • DaysAlive
« Reply #13 on: April 17, 2013, 12:03:49 am »
I don't see any references in the Rigol Chinese or Tequipment docs to this enhancement in the DS2000 firmware:
Offline EEVblog
« Reply #14 on: April 17, 2013, 12:06:45 am »
It really is a classic tit-for-tat between Agilent and Rigol.
Clearly going to be a copy of Agilent's excellent PSU analysis module.
  • Country: aq
    • DaysAlive
« Reply #15 on: April 17, 2013, 12:12:40 am »
Funny!  :)  And I mentioned in another thread that it seems as though this change in the latest firmware:
14.      Changed the RUNT to standard trigger    M
seems like a direct response to the GW-Instek GDS-2000A (which includes the RUNT trigger as standard).
Offline ivan747
« Reply #16 on: April 17, 2013, 12:22:45 am »
I have noticed Rigol started copying certain aspects from different manufacturers. For example, the DS1052E's front panel looks like Tek's low-end offerings but the location of the buttons and knobs resemble Agilent's. Now they are trying to design their signature front panels. They use a lot of diagonal lines and an aggressive style. But they failed at that with their line of  programmable power supplies.
Agilent has created their own rival pretty much in the same way Apple gave Microsoft a place.
Offline Harvs
« Reply #17 on: April 17, 2013, 12:33:26 am »
Nice I hadn't seen that feature.  If it works as well as the other brands, I'll be using it a lot.
So with this AWG, at ~$1100 it's about $250ish more than the normal model.  On paper it seems to out perform their base model DG1022 20MHz dual channel AWG in every way, and for around $100 less.  I'm guessing there's no input for modulation, and at first glance there doesn't seem to be a sync output? Albeit most of the time you're syncing with the scope anyway which I'm sure you could do internal.
Offline ivan747
« Reply #18 on: April 17, 2013, 12:35:39 am »
Dave, do you think you will be able to get a hold of one of these? I'm sure we all want to see it compared to the Agilent 2000 X series AWG and see how did Rigol integrate the AWG in the GUI.  :-DMM
  • Country: aq
    • DaysAlive
« Reply #19 on: April 17, 2013, 12:36:19 am »
Yes, the DS2/4/6XXX, DG4XXX, and DSA8XX series all look like they came from the same industrial designers - but the DP1XXX series doesn't.
« Last Edit: April 17, 2013, 12:47:39 am by marmad »
Offline Hydrawerk
« Reply #20 on: April 17, 2013, 12:42:36 am »
Agilent 2000 X has no arbitrary generator now. Rigol's generator is overall better.
But in Agilent 2000 X there are many hidden features that may be enabled by new firmware, if Agilent guys decide so.
I am not afraid. But they will have to come up with some new very upgraded version of DPO2000.
« Last Edit: April 17, 2013, 12:44:12 am by Hydrawerk »
Offline EEVblog
« Reply #21 on: April 17, 2013, 12:48:59 am »
No idea.
I could ask.
Hassle @RigolTechUSA till he sends me one (and one for Marmad while we are at it!) >:D
I'm sure I could eventually get a loaner from John South at Emona.
  • Country: aq
    • DaysAlive
« Reply #22 on: April 17, 2013, 01:09:30 am »
Perhaps this was mentioned in another thread somewhere - but I couldn't find it in a search. And it may be tangentially related to this same topic (connected to more UltraVision 'add-ons' that have yet to be unveiled), but while searching around online I noticed that there appears to be a concerted push to sell off Rigol's older MSOs. Both Batronix in the EU and Tequipment in NA have clearance prices listed.
Offline grego
« Reply #23 on: April 17, 2013, 01:25:57 am »
I'm desperately trying to get Instek to provide a demo unit to Dave for review.  It makes me sad now that everyone talks only about Agilent and Rigol -- because Dave hasn't done a review on Instek yet!  Ah well, I hope to get that changed soon.
  • Country: aq
    • DaysAlive
« Reply #24 on: April 17, 2013, 01:53:15 am »
Greg, you seem like an objective, intelligent, and articulate guy - you could just do a review yourself as well. There wasn't any info available online about Owon's SDS line when I made my SDS7102 review (and thread here) 18 months ago, and even though I didn't end up keeping it myself, the review triggered a wave of sales and new owners of the DSO - who've since enlarged that thread into the 4th biggest one here. So it doesn't have to be Dave who gets people talking about GW-Instek  :)
