Quote from: alsetalokin4017 on June 30, 2016, 01:05:09 pmAnd yet, you seem to be critical of those of us who have applied that update and are not happy with the problems it introduces. I'm only critical of people of the people who invade every single thread that mentions the DS1054Z and try to turn it into their own personal Rigol-bashing thread.eg. The "DS1054Z noise" thread that you recently invaded.
Rigol-bashing? Moi? Surely you jest. I use the scope every day in my work and I've helped many people understand the scope's quirks and limitations. It gives me great amusement. And I've never once complained about the "loud" fan
When are you going to update your scope to the latest firmware, so that you can have as much fun with it as the rest of us?
@ technogeeky:So what's up with this transistor?
Quote from: alsetalokin4017 on July 06, 2016, 10:11:01 amRigol-bashing? Moi? Surely you jest. I use the scope every day in my work and I've helped many people understand the scope's quirks and limitations. It gives me great amusement. And I've never once complained about the "loud" fanThat's because you work in a noisy room.
https://www.eevblog.com/forum/testgear/rigol-ds1054z-ds1000z-fan-noise/msg649480/#msg649480Quote from: alsetalokin4017 on July 06, 2016, 10:11:01 amWhen are you going to update your scope to the latest firmware, so that you can have as much fun with it as the rest of us?Is the "latest" firmware available to the public yet?
And I also know how to press the encoder shaft-buttons so as not to turn them at the same time -- something that seems to be beyond the ability of some users, who have even gone so far as to tear their scopes apart to replace the encoders.
The latest firmware
No need to be sorry for being annoyed by that "feature". Rigol should've used a rotary encoder with detents for the menu. A smooth one is suboptimal for this purpose.
Occurs the problem with the multipurpose encoder after some time of using?Or just on day one?Honest: I have no problem with it (at least until now). Even if a detent button would have been nicer...
$ strings SparrowAPP.out | grep -i -e limited\! -e pluses+Pluses-PlusesFunction Limited!Parameter Limited!
$ strings SparrowApp.out | grep -i versionVersion: A newer software version detected.An older software version detected.The same software version detected.
