and what about a link that unlock all teh features?
Hint: go to your favorite search engine, and type in "Riglol 1.03d".
Once you get to the page, type in your unit's S/N in the first field, type in
DSER in the
Options field, and leave
Privatekey blank. Then click
Generate. Enter the generated key into the scope, and that's it (how-to is in the .pdf manual).
Doesn't get any easier than that.
Once you get to the page, type in your unit's S/N in the first field, type in DSER in the Options field, and leave Privatekey blank. Then click Generate. Enter the generated key into the scope, and that's it (how-to is in the .pdf manual).
Doesn't get any easier than that. ![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
- IT WORKED WITH DSER OPTINS..THKS
@bingo, how fast is the screen capture on the DS1000z scope? I would think that because it supports png it's probably about 5.5 seconds to transfer a 37KB file already in png format but still transferring data at a mere 57344 bps
I'm getting ~4 seconds using the rigol screenshot utility from lxi-tools (
http://lxi.github.io). Tested on Ubuntu Linux:
real 0m4.094s
user 0m0.000s
sys 0m0.044s
The image is 800 x 480 x 24 and ~1.1MB in size.
Thats a transfer speed of ~2.3 Mbps - I don't think you can get much faster than that on the Rigol 1000z series scope.
... I don't think you can get much faster than that on the Rigol 1000z series scope.
I can !
With my programm via LAN I can get the screen in ~0.9 .. 1.2s
The format is png 800x480 size ~30KB .. 60KB (depends on content).
I can !
DSRemote does the job in less than a second.
I can !
I just gave dsremote a try - to me it seems to also be in the 4 seconds range? (my ethernet link speed is 100 Mbps)
As far as I can tell the image data transferred from a ds1000z series scope is bitmap only and it seems there is no way to change it to png (however, ds2000 series seems to support png).
... the image data transferred from a ds1000z series scope is bitmap only and it seems there is no way to change it to png ...
Why don't you believe me? Transmitted as png and under 1 second.
Look here for testing:
http://homepage.univie.ac.at/zelinkaw54/upload/_Rigol-DSClient.rarProgramming Guide 07-2015 p.79:
:DISP:DATA? ON,0,PNG // transfers a screen as PNG
Seems that PNG support did come with one of the firmware updates
(because the programming guide dated 09-2014, page 2-63, does not mention any parameters for the DISPLAY:DATA? command).
Indeed, after updating my firmware I now have the PNG feature available
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
@ankerwolf: Thanks for the tip. My fastest download now hits about 0.8s .
@karel: I forgot to mention that my interest is ethernet only, not usb but thanks anyway.
Why o why does one have to submit a request form for Rigol firmware and then wait an arbitrary amount of time for someone at Rigol to mail back a link to the firmware???
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
My god Rigol, will ya just make the bloody firmware readily available for direct download on the related product pages - no hiding! Please!
Will this work with any firmware? I'm thinking of picking a brand new one up sometime this week. Please advise. Thanks
Yes.
The unlock code that's generated is based on the unit's S/N, not the hardware/firmware/software revisions.
Yes.
Thanks for the clarification. Very much appreciated and now I feel at ease about the purchase
Works fine here with the latest fw and the version before that.
It did worked for me! I bought a brand new one from tequipament, one month ago. Used the DSER with no problems.
One of my DS1054Z units has a problem, it won't boot, all I get is all lights on and a continuously clicking relay (at approx 5Hz). Anyone had the same problem?
I have not heard of nor encountered a boot failure like that. If it's no longer under warranty, then it'll be interesting to see what the cause is.
If it is no longer under warranty, I would check if it is possible to upload a new firmware via JTAG.
A quick search on the interwebs revealed this:
http://www.jackenhack.com/rigol-ds1054z-oscilloscope-hangs-boot/Only problem with the factory reset procedure is that the menu defaults to Chinese, so you'll have to change that back.
As far as they state on that post, it does retain upgrades if any were made.
Edit: but the freeze on boot on that case showed the Rigol logo so I'm not sure if it is the same problem, worth trying I think.
http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-0019/t/page/fm/0
This page points to a document that says last firmware is Version?00.04.03.02.03 Date?2015-10-20
My 1054Z came today and it says : Software Version 00.04.03.SP2
Which one is the latest ? Is it worth to update ( downgrade ?) to 00.04.03.02.03 ...? ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Anyhow...Riglol did his duty...
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
A.
00.04.03.02.03
is the latest user-installable firmware version (the scope calls this "software version"). In the normal (partial) System Info screen this version is identified as
You can display the _complete_ System Info screen by pressing the Trigger section buttons (extreme right hand side) Menu-Menu-Force-Menu very fast, then Utility-System-System Info. If you don't see the complete system info screen, keep trying, you might not be pressing the Menu-Menu-Force-Menu sequence fast enough.
It is not possible, as far as I know, to "downgrade" or roll back to an earlier firmware (software) version once a later version is installed.
Another way to tell if you have the 00.04.03.02.03 firmware installed is if you have the Pulses and Edges counters in the Horizontal Measurements menus, and the "Pluses" spelling error when you display these as Measurements.
Not the same problem, no. Jackenhack is probably describing the "freeze bug" that I discovered and reported on last year, which seems to afflict many but not all DS1054z scopes with Boot Version 0.0.1.2 when certain user settings are input. Scopes with Boot Version 0.0.1.3 don't seem to suffer from this particular bug.
Yes, it would be nice to know if the Factory Reset (5th left grey button) procedure fixes the problem Mark has.
Do the "enhancements" described in this thread apply to the MSOxxxxZ-S versions as well?
I've got my eyes on an MSO1074Z-S or MSO1104Z-S...
