helo my friend, i buy a new Rigol DS 1054Z . I noticed that all options are on trial for 35 hours that having noticed that every time he lit the oscilloscope expired time, I realized that within 3 or 4 days of use trial versions would have expired. So I immediately made the hack. I performed the procedure as well as on the website by entering the serial number of the model and the code options DSFR and immediately after the result was a code called "private key" that I did not use, and then the serial number consists of four groups of digits and letters. I added this code and all options preinstalled by "trial" became "official" 10MHz, Memory deep 24Mtps etc etc. and the name is changed to the oscilloscope DS 1104Z.
So, I think the result was excellent 100%.
In some forums but I read that you had to enter the code options DSER. Was it not necessary to enter the DSFR. I tried to enter the same data on the site key generator but I put this code options DSER: I noticed that the code "private key" is unchanged while the key code serial instead in the last two groups of letters and numbers is different.
What code was used options? the DSFR or DSER?
My oscilloscope originally had this data:
software vers. 0:04:03
board version 0.1.1.
In the event that the transaction was fair to insert the code DSER options, you can repeat the operation again by entering a second time according to the number of serial key that was entering the second code options?
