Author Topic: New Rigol DS1054Z oscilloscope  (Read 2150008 times)
Offline pascal_sweden
  • Country: no
Re: New Rigol DS1054Z oscilloscope
« Reply #1625 on: August 07, 2015, 01:39:46 am »
No, it was another document. Maybe it actually was a table on a website.
If I stumble on the table again, I will share it here for further reference and discussion :)
Offline Jano
« Reply #1626 on: August 07, 2015, 04:46:30 am »
is latest  firmware/newest production models unlockable to 100MHz etc... ??? has anyone tried?
thanks!
Offline bitseeker
« Reply #1627 on: August 07, 2015, 06:05:09 pm »
thanks!
Mine arrived with firmware 04.03 and it worked fine. I have not tried 04.03.SP1, but others seem to be running fine with it. Give it a try and report back with your results.
Offline saelig
    • Saelig Co. Inc.
« Reply #1628 on: August 07, 2015, 08:34:58 pm »
STOP PRESS! Rigol has authorized a price drop on their DS1074Z 70MHz scope  to $499 & DS1074Z-s (+AWG) down to $699 in case you need another 20MHz bandwidth....
Online ebastler
« Reply #1629 on: August 07, 2015, 08:50:14 pm »
I seem to recall there is another way to get those extra 20 (or 50) MHz... ;-)  But this lowers the entry price for the -S models, which is nice.
« Last Edit: August 07, 2015, 08:52:26 pm by ebastler »
Offline ankerwolf
  • Country: at
« Reply #1630 on: August 08, 2015, 01:35:19 pm »
Hey guys,
I don't fully understand how the DS1054Z is setting Samples/second and MPts based on timebase.
My idea about "Mem Depht", "Sample/second" and "MPts":
1) I think that the resolution of the ADC is only 8 bits.
2) There is a "high resolution mode" up to 12 Bits.
This could be done by sample multiple times within a "SampleTime" and build the Meanvalue.
So you can get out more bits.
I think, I could read it in the manual ...
LG Wolf
« Last Edit: August 08, 2015, 01:51:15 pm by ankerwolf »
Offline ankerwolf
  • Country: at
« Reply #1631 on: August 09, 2015, 06:13:36 pm »
1) are there any commands for the new function "filter"  in the new Firmware 00.04.03.01.05 = 00.04.03.SP1 ?
2) I cannot find Commands for select the graphics format.
Are there some commands?
3) Is there a newer version of the "DS100Z Series Programming Guide" (last is Sept.2014) ?
Thanks
Wolf
Offline ankerwolf
  • Country: at
« Reply #1632 on: August 09, 2015, 08:40:43 pm »
Hello Peter,
Thanks
Offline Jano
« Reply #1633 on: August 12, 2015, 04:07:05 am »
does 1054z firmware 00.04.03.01.05 unlockable?
Online MarkF
« Reply #1634 on: August 12, 2015, 04:19:36 am »
Really?  Too much trouble to even read this one page?  You've already been answered.
   READ!!!
Offline Jano
« Reply #1635 on: August 12, 2015, 06:02:23 am »
MarkF Thank You!  You are so smart!
why dont your read the page yourself more carefully!
Thanks Again!
Online ebastler
« Reply #1636 on: August 12, 2015, 01:56:54 pm »
Jano -- I would agree that page 110 of this thread does not contain an answer based on first-hand experience. But that question has been asked and answered several times in this thread. First one I could find is here:  https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/1530/, and then it feels like the topic is recurring on every other page of the thread... So I can understand Mark's annoyance; this thread is more than long enough without the ever-recurring questions.
(The answer is "yes", by the way.)
Offline Jano
« Reply #1637 on: August 12, 2015, 03:49:40 pm »
to Ebastler
('thanks'  by the way)!
Offline McBryce
« Reply #1638 on: August 12, 2015, 08:37:55 pm »
Maybe a new thread should be opened for each Firmware version?
McBryce.
Offline Fennec
« Reply #1639 on: August 12, 2015, 11:58:09 pm »
Thanks Again!
unbelievable
Offline ankerwolf
  • Country: at
Re: New Rigol DS1054Z oscilloscope - New SCPI-Commands for FILTER
« Reply #1640 on: August 14, 2015, 08:07:37 pm »
Hello,
here are the SCPI-Commands for the new function "FILTER":
"Filter" is new in FW 00.40.03.SP1 (00.40.03.01.05)
  :MATH:OPER FILT         // Operator: S.106: Select Math-Function Filter
  :MATH:DISP OFF          // Operation: ON | 1 | OFF | 0
  :MATH:FILT:TYPE?        // response: LPAS, HPAS, BPAS, BTR
  :MATH:FILT:TYPE BREJECT    // Bandsperre = BTRap = BREJECT
  :MATH:FILT:LLIM?
  :MATH:FILT:ULIM?
  :MATH:FILT:LLIM 2000    // set to 2.0kHz
  :MATH:FILT:ULIM 9500    // set to 9.5kHz
                          // only in steps !!!
                           // W1 = LLIM = lower frequency limit
                          // W2 = ULIM = upper frequency limit
  :MATH:FILT:SOUR?            // does not work
  :MATH:FILT:SOUR CHAN1   // dose not work, S.107 ProgGuide
but it works for FFT:
  :MATH:FFT:SOUR?         // ok for FFT - wrong at S.107
  :MATH:FFT:SOUR CHAN1    // ok for FFT - wrong at S.107
Wolf
Offline quantalume
« Reply #1641 on: August 20, 2015, 07:57:14 pm »
Hi, in the case of single-shot triggering, is there a way to have the scope only record what happens after the trigger event, rather than splitting the memory half before and half after? As it is, half the memory is being wasted at times. Perhaps I shouldn't complain with 24M of memory.  :P
Offline nugglix
« Reply #1642 on: August 20, 2015, 08:17:27 pm »
What about moving the trigger point to the left w/ the horizontal controls?
Should do the trick, or not?
Cheers
Offline McBryce
« Reply #1643 on: August 20, 2015, 08:18:05 pm »
You can move the trigger point to the left of the screen, which should remove any pre-trigger.
McBryce.
Offline quantalume
« Reply #1644 on: August 20, 2015, 09:05:18 pm »
Cheers
Yep, simple enough. Thanks. Only complaint at this point is that the trigger point keeps moving around a bit as I change the time base. Any way to anchor it to the left side? It would be nice if the horizontal position knob zeroed the trigger point to the center on the first click and to the left on the second click, or had a setting somewhere specifying whether zero is the center or the left.
Offline alsetalokin4017
« Reply #1645 on: August 21, 2015, 02:35:36 am »
Cheers
As you change the timebase, the trigger point remains at the same _time_ delay or advance wrt the center of the screen, you can tell this by looking at the "D" value in the very top box second from rightmost.  Hence the orange "T" trigger symbol moves as you change the timebase. Just set it manually wherever you want it before doing a single-shot capture. Is this terribly inconvenient?
Offline quantalume
« Reply #1646 on: August 21, 2015, 03:24:49 pm »
It can be inconvenient at times. For example, if I don't know how long a pulse train is going to be, then I have to keep changing the time base and repositioning the trigger point. I've resigned myself to just sticking with the center of the screen as the trigger zero point, at least until I've learned more about the waveform under observation.
Offline MT
  • Country: aq
« Reply #1647 on: August 21, 2015, 06:54:26 pm »
I was about to buy a 1054z but sadly to say i had a second thought because i come across the 1054 bug and wish list and the fact the input bandwith is dived among the channels but my problem is i dont need all the fancy bells and whistles, i happily trade RS232, SPI, maths etc, etc for increased bandwith/speed and simplicity.What i need is scope that do example 400Mhz, FFT, freq counting,PW and and who can do screen dumps in a suitable bitmap format for similarly amount of money and that's about it. I dont have the time or patience to read all the million posts about different scopes but with my requirements i'm i stuck with old secondhand analogs market or is there something new like this around?
Thanks for any info and your time regarding this!
« Last Edit: August 21, 2015, 06:56:02 pm by MT »
« Reply #1648 on: August 21, 2015, 07:15:25 pm »
Is there some kind of scope that acts differently? Don't we all do just exactly this when we are looking at a waveform for the first time?
Could you use the Rigol's advanced triggering features, like "nth edge" or "delayed" for example, to get more of what you want?
« Reply #1649 on: August 21, 2015, 07:20:35 pm »
Well.... if you can find a 4-channel secondhand analog scope with 400 MHz bw that will do FFT, Frequency counting, pulse width and screendumps for 400 dollars, and comes with 4 probes... buy it, by all means!
Otherwise, get a Rigol 1054z, unlock it to 100 MHz and just don't use the features you don't want. Do you really need 400 MHz bandwidth, on your budget?
Is there an inexpensive DSO that does not "divide input bandwidth among the channels?"
