I just did a capture in Putty , and displayed with Bless (Linux Hexeditor)
My capture is 1.2MB in size , and has a BMP Header
So it seems the DS1054Z also sends bitmaps , and the Py program is converting to .png
/Bingo
@miguelvp
Did you modify Alec's VXI11 in order to run the program ?
I might give it a shot , but miss a "short stepguide" in order to install it (vxi11) , and the other ones he has.
/Bingo
@miguelvp
/Bingo
No modification, I guess I modified the comment and forgot to take out the modified part.
As for installing, in the readme in:
https://github.com/alexforencich/python-vxi11the installation is:
python setup.py install
Edit:
Also I did modify the ping to have a timeout other than the default one with -w 20 for 20 milliseconds for the ping.
Rigol DS1054Z
SW. 00.04.02 SP4
HW 0.1.1
With all updates incl. 5mV option.
Updated with the firmware link over my post. Auto-Calibration with the cold scope.
5mV option still not usable. Hardware version was 0.2.2 after reboot and cal. The bugs must be resoldered my board.
After a few restarts it's back to HW. 0.1.1 now. (the bugs seems still soldering.)
Checked maybe 5min. and I see no differents. More later, have to work.
@miguelvp
/Bingo
I got 4 seconds transfers via VXI-11, way faster than even a thumb drive attached to the scope.
I'm following this subtopic here:
https://www.eevblog.com/forum/testgear/python-based-instrument-control/msg676772/#msg676772This probably applies to other rigol tools as well that are slower on ethernet than using usb, like Marmad's RUU
@miguelvp
/Bingo
I'm a total layman. Maybe the ethernet controller is connected by USB and causes a bottleneck?
Great find
(debugging)
Now i'll have to install VXI-11 , also because i know Alex might have improved the linux-gpib support
/Bingo
Can someone PM me the Tequipment.net discount code. I need a new 'scope!
Thank you.
Darryl
Recently I was trying to figure out why one of my RP2200 probes was completely unusable at 1:1 attenuation. The switch seemed to be a bit dicky so I took the plastic bit off and here is what I found.
I don't know whether this was done on purpose or it's just a flash from injection molding, but it seems to prevent the switch from sliding into the '1x' position properly. So I scraped this bit off and sanded the area with a small file, and guess what - my probe is usable at 1:1 once again!
Thanks for the tip, All 4 of my probes were 'jumpy' on the x1 setting but no problem on the 10x setting
I took the yellow selector knob off and cut away that bit of plastic.
Great news is that all 4 probes are perfectly stable at 1x setting now, much happier.
Regards
I have just RMA'ed my DS1054Z at Batronix
I have had it just a week.
It locks up after a few hours turn on time , and all buttons are dead.
Sometimes it locks up showing the captured waveform , and sometimes it crashes and shows garbage on the screen, like the attached picture.
Will let you know how it goes
/Bingo
Followup here
https://www.eevblog.com/forum/testgear/batronix-a-mixed-ds1054z-rma-experience/
I wonder whether the continuing reports of dodgy probes is a result of success! I bought my 1074-S nearly 2 years ago and have encountered no problems with my probes (so far).
I don't want to read 500 posts. Is the jitter problem, as well as any other bugs, fixed now for the DS1054Z? Will I have to upgrade the firmware if its fixed, or will it come fixed?
A friend received his 1054Z last week and it came with the latest firmware (4.02?) and that fixes the jitter problem.
I don't know about fixes for anything else, it was also still "hackable" if that matters to you.
It should be sufficient to read the
first post of this thread, where rolycat is maintaining a short FAQ section which answers this and other questions.
kenw32 - that's partly why the thread is so long - OOPS
Rigol posted new firmware at
http://beyondmeasure.rigoltech.com/acton/fs/blocks/showLandingPage/a/1579/p/p-0019/t/page/fm/0 with the fix for the jitter problem.
The zip filename shows version 00.04.02.04.07 but inside the directory name shows version 00.04.03.00.01.
I've been running the 04.02.SP4 version that I downloaded from the link above when it was first posted with no problems. I have not tried the 04.03.00 version yet. I saw a few posts else where that said version 04.03 works okay. I'd like to hear what new changes that have been made in the new version if anyone finds out.
I wonder if Rigol has refined the PLL coefficients more? I don't have the means to measure the PLL clock though.
I upgraded to 4.03 today and it kept all my hacked installed options. Not sure if I was supposed to uninstall them first or not. It kept 500uv which I should get rid of. Not sure if I can reinstall another hacked options minus the 500uv over the top of what I already have or not...
JimmyK
You need to uninstall all options to remove the 500uV option by using the SCPI command :SYSTem:OPTion:UNINSTall, then reboot the oscilloscope. The SCPI command must be sent via the USB or LAN port.
Then reinstall your desired options (use DSER for all options except 500uV option).
I received my DS1054Z recently and I am very pleased with it. I have updated it to the latest F/W 04.03 with no problems but as I am new to the scope any changes to performance are not apparent. It still works! A problem I do have is using Ultra Sigma on Windows 7 64bit. The s/w boots OK and recognizes the DS1054Z, via either USB or LAN, but does not react to SCPI commands except the IDN? which works OK. Trying the :SYSTem:OPTion:UNINSTall command it fails with a timeout response 'insuffient time to complete'. Extending the 'timeout' in advanced mode doesn't help. The Ultra Sigma s/w supplied refers to Version 2 on the CD but this is older than the downloadable s/w version on the Rigol website. I have tried both versions but neither works correctly. Does anyone know of a solution for this problem?
Thanks John
If you decide you want to write some code, my DS1074Z responds to TCP ports 5555 and 5566. You should be able to telnet on those ports also.
Anyone has lost USB connectivity upgrading to 04.03? Something weird going on here. Device is seen in Windows with proper IVI driver loaded, but not detected.
Only happens with the Keysight I/O Libraries installed. Works fine with NI-Visa only. Doesn't work with I/O Libraries also installed.
