I just received my new 1054Z from Tequipment, and it "upgraded" successfully to a 1104Z, and I really like it.
I'm having trouble, though, with one thing. I can't seem to figure out how to dump a recorded waveform to a CSV file on a thumb drive. I've googled my fingers to a nub, and I see people complaining about how slow the process is, but I don't see any one saying how they actually did it. Whenever I save, I only get one frame of the 5000 or so I have in recorded memory, and I select Datasrc as Memory, not Screen. I've got sequence to ON, which I assumed would create a csv file sequentially numbered for each frame, but it does not ( I can really figure out what that does).
Does anyone know how to dump the entire recorded data into CSV file(s)? Also, does anyone know what Sequence ON/OFF does? It says "Press Sequence to choose whether to add the sequence number for the CSVfile. You can select “ON”or “OFF”and the default is “ON”(namely add the sequence number for the CSV file).", but that isn't all that informative.
