Author Topic: New Rigol DS1054Z oscilloscope  (Read 2133816 times)
xKertx and 12 Guests are viewing this topic.
Offline JPortici
Re: New Rigol DS1054Z oscilloscope
« Reply #3850 on: June 01, 2017, 10:46:17 am »
have to agree, i had a surface 3 for some time and it was a really neat tool
Offline Loboscope
« Reply #3851 on: June 01, 2017, 11:31:06 am »
A scope (and a DMM of course) will be useful for troubleshooting and repairing any gear in general (amplifers, PSU, etc.), but not for measuring THD and noise, especially at low levels.
To do this (and more), I use "hpw-works" [http://www.hpw-works.com/], together with a good interface (RME or comparable) - a really professional solution.
The following users thanked this post: AudioNoob
Offline Daque
« Reply #3852 on: June 01, 2017, 02:14:56 pm »
Can you dump a  I2C capture and use the data fix in another program to decode the data? If so what program would you use? I understand the scope's decoding could be better. The  data I want to decode at is very small and sent over up to about 10 seconds.  Basically a few bytes to start playback or record  at an address of a ChipCoder chip  then stop it at the end of message. Would one of those $6 eBay logic analyzes work better for this? There is a 3rd line that the chip sends out a timing sync pulse every 32 milliseconds that I want to take a look at eventually too.
Sent from my iPhone using Tapatalk
« Last Edit: June 01, 2017, 02:18:00 pm by Daque »
Online rstofer
« Reply #3853 on: June 01, 2017, 02:39:31 pm »
none is good.
-8 bit digitizer
- too much noise (a side effect of having a very high bandwidth
an audio interface, or a dc coupled audio interface, and a software suite is probably the best choice before ending up spending multi thousand dollars on audio analyzers
For audio, I would think the Digilent Analog Discovery with 14 bit ADC would be ideal.  It knows all about Bode' plots and FFTs.
Online rstofer
« Reply #3854 on: June 01, 2017, 02:44:02 pm »
I have a high end Surface Pros and Surface Book.  There is no way in the world I would ever use the audio system to troubleshoot external stuff!  These things cost a whole lot of money - far more than a decent scope.
I do use the Digilent Analog Discovery which is USB based but, even then, I plug it into a powered hub.
Offline Fungus
« Reply #3855 on: June 01, 2017, 03:06:04 pm »
I want to decode I2C...  Would one of those $6 eBay logic analyzes work better for this?
Probably.
A 'scope is essential for troubleshooting I2C problems and making sure the bus is OK (good pullups, etc.) but one of those $6 eBay analyzers will win for collecting/decoding long streams of data from working devices.
« Last Edit: June 01, 2017, 03:07:56 pm by Fungus »
Offline Daque
« Reply #3856 on: June 01, 2017, 03:36:20 pm »
Thanks.  I have one coming but it could still be a month out.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3857 on: June 01, 2017, 07:20:31 pm »
Welcome to the forum.
Consider adding SDS1202X-E to your list. Bit dearer than a 1072 @ $379 but 200 MHz and excellent FFT.
I certainly don't need high bandwidth (or do I just not realize that I need it?), but excellent FFT is definitely a selling point. So, will FFT actually be useful for seeing small (inaudible) distortions of audio signals?
It will be better than the others on your list due to its 1 Mpts FFT.
Some screenshots:
https://www.eevblog.com/forum/testgear/new-siglent-sds1000x-e-oscilloscope-based-on-xilinx-zynq-7000-soc-architecture/msg1192654/#msg1192654
can we possibly download the whole 14Mpts data and plot FFT in PC like DS1054Z 24Mpts FFT like below?
Offline tautech
« Reply #3858 on: June 01, 2017, 08:48:14 pm »
Outside my field but I'll see what I can do. Bookmarked.
Edit.
Yes but we're waiting for the programming manual to be finalised.
Can you provide a link to VISADSO please.
Are you pulling the data via LAN or USB ?
« Last Edit: June 02, 2017, 09:20:15 pm by tautech »
Out of office and unavailable for a few days.
Offline Fungus
« Reply #3859 on: June 02, 2017, 06:55:06 am »
Probably, but... it's still an 8-bit ADC and that's the real limiting factor. No amount of buffer will remove the noise introduced in the signal by the ADC.
« Last Edit: June 02, 2017, 06:57:38 am by Fungus »
Offline AudioNoob
  • Country: ua
« Reply #3860 on: June 02, 2017, 07:07:56 am »
8 bit means means ~48 dB SNR, is that why it's limiting? Subsequently, a perfect sine wave quantized in 8 bits would exhibit a certain (rather high) THD percentage due to that -48 dB random noise added to it. Am I getting it right?
Offline Fungus
« Reply #3861 on: June 02, 2017, 07:31:46 am »
You'll see all the big frequency peaks but the noise will mask the small ones.
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #3862 on: June 02, 2017, 07:56:38 am »
You can do what some THD analyzers and other equipment do; which is to place a notch filter on the fundamental frequency. You can continue down this path, if you wish, placing it on subsequent harmonics until you run into the genuine noise floor of the instrument.
Offline boggis the cat
« Reply #3863 on: June 03, 2017, 12:57:15 pm »
It is this software: http://www.soasystem.com/download/visadso/
Only working with some Rigol models at the moment.
Offline lacommtech
« Reply #3864 on: June 05, 2017, 06:02:20 pm »
Hope that this isn't off-topic.
Does anyone who's purchased one lately know whether the upgrade hacks still work?  I'm getting closer to buying one, figuring that eventually they will make it harder to permanently enable what they offer as trial features and that my old Tektronics may decide to retire soon.
Thanks in advance for any info!
Online ebastler
« Reply #3865 on: June 05, 2017, 06:13:56 pm »
Not off-topic, but rather repetitive.  ::)
Yes, the upgrade hacks still work. Don't buy an MSO or a "plus" model, though; these are (and always have been) much more difficult to hack.
Offline pmayhew
« Reply #3866 on: June 11, 2017, 08:37:14 am »
Hi, I have the Rigol SD1054z, and used the http://gotroot.ca/rigol/riglol/ page for the modification.
Unfortunately I wasn't aware of this forum until now, and have installed all options DSFR and was not aware there was a bug at 500uV (I've not seen this bug myself)
I understand that all options can be remove, but I have been unable to find and download the UltraSigma software. Do any anyone here have a working download link, or can provide me with this program?
Is the bug only when reducing the amplitude to 500uv?
Peter
« Last Edit: June 11, 2017, 08:39:14 am by pmayhew »
Offline Fungus
« Reply #3867 on: June 11, 2017, 11:10:32 am »
You don't need any special software. Just connect it to your PC with an Ethernet cable and open a command line.
Type this:
telnet XX.XX.XX.XX:5555            (where XX is the IP address of the 'scope).
If you don't see any messages saying 'unable to connect' then type:
:SYSTem:OPTion:UNINSTall
This removes all the options so you can start again.
While you're there you can install the options via command line as well. Use this to enter a key:
:SYSTem:OPTion:INSTall XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Where XXXX is a key generated by Riglol.
Yes.
« Last Edit: June 11, 2017, 11:15:57 am by Fungus »
The following users thanked this post: made2hack
Offline kjh83
« Reply #3868 on: June 12, 2017, 02:41:58 am »
Peter
I haven't tried it but code DSER should install everything but the 500uV/div feature. It's not listed on the webpage you used but it should work once you've reset all the options. I wouldn't mess with the 500uV feature if your scope doesn't have the hardware for it.
YMMV.
Offline ebclr
« Reply #3869 on: June 12, 2017, 04:42:37 am »
I may don't know how to recognize the bug, but my work just fine on 500uV
Maybe that is a more sophisticated bug other than just see the waveform on 500uV
Online ebastler
« Reply #3870 on: June 12, 2017, 07:51:55 am »
If I recall correctly, one of the issues is a big jump in the offset which cannot be removed by self-calibration. But I can't find the thread where this was discussed at the moment.
In any case, there is little benefit to be had from a 500µV/div scale on the DS1054Z. The 1mV/div scale is already a digital zoom (i.e. visual magnification only, without gaining ADC resolution). And the analog input noise will probably prevent you from seeing much additional detail at 500µV as well.
Offline ebclr
« Reply #3871 on: June 12, 2017, 10:38:36 am »
I'm lucky 1/2 division only,
Offline Hydron
« Reply #3872 on: June 12, 2017, 12:33:04 pm »
The DS1000Z series only has 2 analogue ranges, with an attenuator switched in for 500mV/div up to the max of 10V/div.
All other gain control is done digitally inside the HMCAD1511 ADC (it has internal precision >8 bits, and thus can do digital gain control over a fairly wide range), which Rigol has taken advantage of in order to make the analogue front end very inexpensive. However this digital gain has a max of 50x, with missing codes at gains higher than 32x (see HMCAD1511 datasheet).
As Rigol is using the same analogue gain for all ranges 200mV/div and under, best case is that they'll be hitting >32x digital gain (and therefore the ADC output will have missing codes) at 5mV/div, and will be beyond 50x at 2mV/div and 1mV/div, so will need software gain for these two settings. There will also be some decrease in ENOB as digital gain is increased - the datasheet specs 7.9 bits at 1x going down to 7.6 bits at 10x gain (which actually seems like a pretty good performance to me!)
tl;dr: it's already run out of steam at <5mV/div, don't worry about trying to do any better! You won't get amazing performance out of a DS1000Z scope, but you might get amazing value if your use doesn't push it's limits.
« Last Edit: June 12, 2017, 12:36:14 pm by Hydron »
The following users thanked this post: ebastler, tooki
Offline Fungus
« Reply #3873 on: June 12, 2017, 01:06:44 pm »
Nothing massively bad happens on that range but it doesn't work very well. It's best not to be able to select it accidentally.
Offline David Hess
  • DavidH
« Reply #3874 on: June 12, 2017, 01:16:38 pm »
It only has one attenuator section before the high impedance buffer.
Is that right?  I thought Rigol was using one of National's LMH series of digitally controlled, variable gain amplifiers between the high impedance buffer, transistor preamplifier, and the ADC.  The DS2000A series uses the LMH6518 and as I recall, photographs of the DS1000Z series show an integrated circuit in this location but the markings are removed so it is not clear exactly which LMH part is used.
« Last Edit: June 12, 2017, 07:21:34 pm by David Hess »
